rear disc swap ?.......searched
I have the rear disc brakes off of a 94 integra ls but i dont have the trailing arms from the teg.......i only have the rear hubs.....my question is: am i able to bolt up the hubs up to my trailing arms on my 98 hatch?........i have heard conflicting stories: some say it will work, some say it won't.....
cool......i will have to see if i can get that bracket.......also, will i be able to use my brake lines or do i need the teg lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purple98ek »</TD></TR><TR><TD CLASS="quote">cool......i will have to see if i can get that bracket.......also, will i be able to use my brake lines or do i need the teg lines?</TD></TR></TABLE>
do you have the e-brake cables as well. If not you will need to get those. I did a similar swap on mine but I had the complete setup. The bolts holding the stock hub on has loctite on it so you will need to make sure that you have it in something that will allow you to get some good leverage or you will strip the bolts out.
I used a standard vise to hold mine in place
Josh22999
Mar 28, 2007 10:30 AM
1CiViC1
Feb 15, 2004 06:55 PM
