ECU error codes
Old May 22, 2007 | 05:38 PM
slow91ed8's Avatar
Default ECU error codes
I have a 91 CRX with a B16A in it and today it started throwing Code #2 and Code #6 and I was wondering if anyone knew how to fix those or point me in the right direction?
Old May 22, 2007 | 05:49 PM
EF_LSVtec's Avatar
Default Re: ECU error codes (slow91ed8)
I'm assuming you're using a PR3 ecu? Code 2 is bad O2 sensor...it looks like a spark plug sensor on your exhaust header...cheap replacement...
Code 6, coolant temp sensor, found on the cyl head under the top coolant hose...clean connections and reset ecu...or replace sensor itself.
Old May 22, 2007 | 05:52 PM
slow91ed8's Avatar
Default Re: ECU error codes (EF_LSVtec)
Yeah I am using a PR3 and thanks for your help. Ill fix that tomorrow.
Old May 22, 2007 | 05:53 PM
slow91ed8's Avatar
But off that top of my head I do not think there is a O2 sensor on the header. Unless its on the very bottom.
Old May 22, 2007 | 06:02 PM
EF_LSVtec's Avatar
yeah, same thing...
Old May 22, 2007 | 06:05 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91ed8 &raquo;</TD></TR><TR><TD CLASS="quote">But off that top of my head I do not think there is a O2 sensor on the header. Unless its on the very bottom.</TD></TR></TABLE>
It has to be at the top, because its not a heated 02 sensor. Do you have two of them hooked up as well ?
Old May 22, 2007 | 06:07 PM
slow91ed8's Avatar
It looks like there is no o2 sensor there.
Old May 22, 2007 | 06:08 PM
I can see it, its behind the header.
Old May 22, 2007 | 06:12 PM
slow91ed8's Avatar
Default Re: ECU error codes (RCautoworks)
Is it the one I circled in red?
Old May 22, 2007 | 06:13 PM
Yes, you need to have two though, around that area.
RB_EJ8
Oct 1, 2008 11:14 PM
91GS-R in Vegas
Dec 20, 2007 04:55 PM
draxxus07
Sep 29, 2005 11:35 AM
Lewie
Jun 30, 2004 11:33 AM
chambersef8
May 14, 2004 01:12 PM
