Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Koni Yellow Inserts
Old May 22, 2007 | 03:53 PM
cherrynutz's Avatar
Default Koni Yellow Inserts
Sorry. Just don't know to much about struts. So I'm looking to get the Koni Yellows, but not sure why it's called an insert. The one website said "Special McPherson strut insert bolted into O.E. housing after cutting top and removing old internal parts." I have KYBs on now and not really happy with them. On this website they have 55mm outside diameter. I can't remember what the KYBs are...any help is appreciated. Thanks. Dustin
Old May 22, 2007 | 03:59 PM
Boilermaker1's Avatar
you'll probably have to do em in stock housings if you want them to fit right. I doubt the KYB housing is exactly the same. Just measure the diameter of the housing above the spring seat.
Old May 23, 2007 | 03:05 PM
cherrynutz's Avatar
Default Re: (Boilermaker1)
So what exactly am I gonna have to cut? Any specialty tools I might need? What would you rate this on the difficulty scale? Thanks again
Old May 23, 2007 | 03:57 PM
ES2's Avatar
ES2
Default Re: (cherrynutz)
Check out this site: http://forums.nasioc.com/forum...19607
The basic steps are there, but you may have to modify some steps (like how much of the strut to cut) since our struts are different from the subaru impreza.
Old May 23, 2007 | 04:09 PM
cherrynutz's Avatar
Default Re: (ES2)
That helps a lot. I did a search on how to install strut inserts on Google and didn't really come up with nothing. On an unrelated topic...got any pictures of your strut bar? Would you ship?
Old May 23, 2007 | 04:50 PM
Curiouz_G's Avatar
boilermaker has made a thread about it with pictures on http://www.civicforums.com. its basically the same as that but for a civic obviously. Honda Tuner magazine also installed it with a DIY with pictures on its website for a 01 with 50MM Koni's
Old May 23, 2007 | 05:00 PM
cherrynutz's Avatar
Default Re: (Curiouz_G)
See that is another question. The website showed the EM2 fitting with 55mm and then the next set of strut inserts they had was 50mm. The only thing is that it said "EM2? Coupe." So I'm really not sure witch ones to go with. Here is a link to that website
http://replacement.autopartswa...=true
Old May 24, 2007 | 08:08 AM
Killtodie's Avatar
* B A N N E D *
DO NOT get inserts.
It sucks that Koni doesnt make full struts, buit DO NOT GET THE INSERTS! it caused me a LOT of pain.
Mainly because stupid n00bs put it in and fucked my car
Old May 24, 2007 | 08:14 AM
OSK Automotive's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherrynutz &raquo;</TD></TR><TR><TD CLASS="quote">See that is another question. The website showed the EM2 fitting with 55mm and then the next set of strut inserts they had was 50mm. The only thing is that it said "EM2? Coupe." So I'm really not sure witch ones to go with. Here is a link to that website
http://replacement.autopartswa...=true</TD></TR></TABLE>
What year is your car? 01s should be 50mm, 02s are mixed, and 03s+ should be 55mm. I would measure just to be sure.
Old May 24, 2007 | 09:19 AM
efficiencyJunkie's Avatar
Default Re: (OSK Automotive)
I went out and bought the wrong ones too.
Anyways here is the honda tuning magazine article.
http://www.hondatuningmagazine...nsion/
Btw; I do have some 01-03 Koni Yellows (50mm) brand new for sale, because they didnt fit my car!
Old May 24, 2007 | 10:17 AM
cherrynutz's Avatar
I have an 03 EX Coupe.
Old May 24, 2007 | 01:19 PM
Killtodie's Avatar
* B A N N E D *
03 was a hard year. some 03s use 55mm some use 50mm.
like i said, dont recomand koni inserts.
Old May 24, 2007 | 09:14 PM
Curiouz_G's Avatar
just because theyre hard to install doesnt mean theyre bad products
Old May 25, 2007 | 08:29 AM
cherrynutz's Avatar
Default Re: (Killtodie)
What about this set of Tokico Blues. Found them on ebay. Anyone ever heard anything about them?
http://cgi.ebay.com/ebaymotors...QrdZ1
dpine
Suspension & Brakes
Feb 17, 2014 07:23 AM
Hondakorn
Mar 13, 2009 11:30 AM
swoosher21
Jan 11, 2005 04:40 AM
Solo2Vtec
Apr 29, 2003 11:02 AM
pcorad
Jul 30, 2002 12:40 PM
