Koni Yellow Shock Install Help Please
Old Apr 28, 2003 | 09:47 PM
Solo2Vtec's Avatar
Default Koni Yellow Shock Install Help Please
I bought a set of Koni Yellow shocks for 94 RS Integra. Everything was going smoothly installing untill I noticed the the medel cylinder the bushings go around is not large enough for the shaft to go thru. This is at the very top of the shock tower. Does anyone know where I buy the right part? Thanks
Old Apr 28, 2003 | 10:15 PM
RangerDan's Avatar
Default Re: Koni Yellow Shock Install Help Please (Solo2Vtec)
Normally with Konis you need an adaptor. Check with http://www.Tornactive.com he should have them in stock for like 45.00 bucks (please dont quote me on that)
Old Apr 29, 2003 | 09:05 AM
Solo2Vtec's Avatar
Default Re: Koni Yellow Shock Install Help Please (RangerDan)
Anyone else ?
Old Apr 29, 2003 | 09:37 AM
D0HC's Avatar
Call Koni... I am not sure what part your talking about but their CS is great and I am sure they will be able to help. You can find their contact info on their web site.
Old Apr 29, 2003 | 09:41 AM
BROOD's Avatar
I think you are talking about the strut dust cover.
The hole needs to be opened up to 12mm (1/2" or so) to allow the Koni piston rod to go through. It is easy to do, a drill press makes thing safer/easier but a hand drill and vise would work fine.
Or if you mean #12 (the spacer bushing) it should have come with the Koni's
#10 in the pic below
Modified by SLPR at 11:04 AM 4/29/2003
Old Apr 29, 2003 | 09:48 AM
Solo2Vtec's Avatar
Default Re: Koni Yellow Shock Install Help Please (SLPR)
Thanks guys I figured it out. Turns out my shocks were missing a few pieces. Thanks Guys!
Christian
Old Apr 29, 2003 | 11:02 AM
Audi RS4's Avatar
Lover
use a round file, easy as that............
3rdgen3
Suspension & Brakes
13
Jan 26, 2011 09:24 PM
swoosher21
Jan 11, 2005 04:40 AM
rubens
Jul 18, 2003 09:11 PM
Solo2Vtec
Apr 26, 2003 05:24 AM
DevinW
May 7, 2002 05:27 PM
