HELP! CEL LIGHT ON/CAR EATING ANTIFREEZE!!!
Old May 22, 2007 | 03:42 PM
turboeg831's Avatar
Default HELP! CEL LIGHT ON/CAR EATING ANTIFREEZE!!!
I started up the car today with no problem, and drove about a good 40 miles until my car started smoking. Pulled to the side, and popped the hood. There was no antifreeze in the reservoir, so I went to fill it up. The smoking stopped for a little until about 10 miles later when it started smoking worse. Now the car is smoking worse and worse, also popped the hood and checked again. The antifreeze I just filled up into the reservoir is all gone. What's going on?! Throughout the period of smoking, the CEL is on!!!! PLEASE HELP!!!
Old May 22, 2007 | 03:49 PM
turboeg831's Avatar
#6: ECT - water temperature sensor
What do I do next?~??~?~
Old May 22, 2007 | 03:56 PM
Mr.EM1_EK's Avatar
Default Re: (turboeg831)
maybe you need a new sensor. does the car overheat? my guess is its blowing your coolant out of the reservoir itself. make sure the radiator is full.
Old May 22, 2007 | 07:53 PM
jasonthehatchman's Avatar
Default Re: (Mr.EM1_EK)
or there is the possibility that you blew a headgasket and now it is dumping antifreeze into the cylinders cause it to burn off, especially if you have boost and it is stock internals and head gaskets too
Old May 23, 2007 | 01:01 PM
turboeg831's Avatar
My car has never been boosted. It's just a beater d16y7 with NO modifications WHATSOEVER!
Well anyways, update on the situation. I just replaced the sensor, but the CEL is still on. Do I have to reset the ECU? Stupid me, I didn't reset the ecu, now the same thing is happening again. The blowing of the coolant still persists. What do I do now!? Thanks!!!
Old May 23, 2007 | 02:20 PM
turboeg831's Avatar
Can anyone please help?
Old May 23, 2007 | 02:27 PM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: (jasonthehatchman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasonthehatchman &raquo;</TD></TR><TR><TD CLASS="quote">or there is the possibility that you blew a headgasket and now it is dumping antifreeze into the cylinders.</TD></TR></TABLE>
I 2nd this, burning massive amounts of coolant points towards a blown headgasket, no better time for a mini-me swap ^^
Also CEL light is probably coming on becuase your burning up all your coolant and the sensor cant read air, so it throws a trouble code.
Old May 23, 2007 | 02:28 PM
turboeg831's Avatar
So it might be a blown head gasket eh? What are the distinct signs that show it? Where do I go from here?
Old May 23, 2007 | 02:35 PM
turboeg831's Avatar
I looked into the reservoir, the anti freeze looks really weird. It looks like normal anti freeze but with algae... =/ ?
Old May 23, 2007 | 03:11 PM
crispy93's Avatar
my votes on the blown head gasket
Old May 23, 2007 | 04:01 PM
NOman0608's Avatar
Default Re: HELP! CEL LIGHT ON/CAR EATING ANTIFREEZE!!! (turboeg831)
blown head gasket with out a doubt.. hows your oil lookin?
Old May 23, 2007 | 04:14 PM
turboeg831's Avatar
How bad is a blown headgasket? About how much is it to be fixed??
Old May 23, 2007 | 04:47 PM
cimo463's Avatar
Thats a blown headgasket! Its an easy fix (if you know what you are doing). A shop is prob gonna charge you anywhere from $500-$1000
Old May 23, 2007 | 05:03 PM
turboeg831's Avatar
Does anyone have a tutorial anywhere? Thanks.
Hughie1987
Oct 21, 2014 11:42 AM
tejano_honda
Oct 2, 2007 09:34 AM
Dumped DB2
Dec 28, 2004 01:57 PM
92GSR
Jul 29, 2002 08:16 AM
