95 Civic gas gauge
Old May 22, 2007 | 01:06 PM
EG8Master's Avatar
Default 95 Civic gas gauge
i am so frustrated cause the gauge isnt accurate so i never know how much i got plus the inaccuracy makes it look like my MPG sucks too is there a fix?
Old May 22, 2007 | 01:12 PM
FalkenSiR's Avatar
Default Re: 95 Civic gas gauge (EG8Master)
Hondas are inaccurate period. Now, if you think it's too inaccurate, compare it with someone else's EG gauge.
Old May 22, 2007 | 01:31 PM
EG8Master's Avatar
what do i do if mine is worse?
Old May 22, 2007 | 01:34 PM
FalkenSiR's Avatar
The easiest would be to borrow someone else's cluster and see if it still does it. If it still does it, then the problem is in the fuel sender unit/sensor in the gas tank.
Old May 22, 2007 | 02:58 PM
97Ej6mike's Avatar
They do make aftermarket guages, which do run and measure on their own system (fuel level) , but that stuff is probably more trouble than its worth. Your best bet, as said by falkenSIR is to borrow a friends cluster for a period of time, and see if that makes a difference.
Old May 23, 2007 | 10:44 AM
EG8Master's Avatar
Oh i forgot to say couple months ago i swapped my original for a jdm EG cluster so i dont think its the cluster. so im gonna try replacing the fuel sending unit and see how it is after that.
hirogx
Mar 12, 2011 07:59 AM
tifosi
Jul 11, 2008 10:13 AM
gwegcivic
Feb 18, 2008 12:45 AM
B6tizzleHatch
Aug 2, 2006 07:06 AM
