G23 Code 17 on deceleration
94 Accord H23/F22 Accord ECU
As the post title says, I'm throwing code 17 (injector error) when I let off the gas and decelerate.
Has anybody had this issue before? Would the injectors need to be replaced or just cleaned? I tried the fuel additive (injector cleaner) but that has not done anything. When I start the car there's no CEL, but if I allow the car to decelerate by letting off the gas I throw the code. If I accelerate quickly I also will throw that code.
Thoughts?
Thoughts?
IIRC Code 17 is the VSS (Speed Sensor), a buddy of mine just threw a code 17 on his car after he did his swap.
ref: https://honda-tech.com/zerothread/1901557
-l8r
-l8r
it could be the connector to the vss isnt secure or as happened to mine, the little tab that the bolt goes through is broken and every time you accelerate the vss pops out just a little. Then when you slow down it catches again and sends the code.
BoostedH23Accord
May 23, 2007 02:16 AM
