02 sensor for a 95 civic with B swap.
Old May 22, 2007 | 02:40 AM
fitbmx86's Avatar
Default 02 sensor for a 95 civic with B swap.
i've been using the stock one that was on my D series. needs to be replaced, do i go for the Intergra LS one since im running that ecu now or do i just get the same 95 dx one? they are prob the same but i just want to be sure.
Old May 22, 2007 | 01:01 PM
fitbmx86's Avatar
Default Re: 02 sensor for a 95 civic with B swap. (fitbmx86)
anyone?
Old May 22, 2007 | 01:14 PM
FalkenSiR's Avatar
If you are running an LS ecu, then it makes perfect logic to go with an LS O2 sensor.
Old May 22, 2007 | 01:20 PM
philosofy1's Avatar
Default Re: 02 sensor for a 95 civic with B swap. (FalkenSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">If you are running an LS ecu, then it makes perfect logic to go with an LS O2 sensor.</TD></TR></TABLE>
not sure if they are the same, but since the op has a dx, i take it no modifcation was needed to complete his swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fitbmx86 &raquo;</TD></TR><TR><TD CLASS="quote">i've been using the stock one that was on my D series. needs to be replaced, do i go for the Intergra LS one since im running that ecu now or do i just get the same 95 dx one? they are prob the same but i just want to be sure.</TD></TR></TABLE>
go with the O2 sensor for your civic. this is what i did when i replaced mine and i have a b16.
Old May 22, 2007 | 01:30 PM
93egsir's Avatar
if you had no codes with the dx o2 then you should be fine with a new civic dx one
Old May 22, 2007 | 01:36 PM
FalkenSiR's Avatar
Default Re: (93egsir)
lol why would you want to have the wrong o2 sensor that the ECU was meant to have? somebody please answer that question.
Old May 22, 2007 | 01:58 PM
philosofy1's Avatar
Default Re: (FalkenSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">lol why would you want to have the wrong o2 sensor that the ECU was meant to have? somebody please answer that question. </TD></TR></TABLE>
don't look at it like ecu and o2 sensor. what if his ls is a 96-01 motor/ecu. then technically his ecu would be looking for 2 o2 sensors. the 92-95 civic's only have one o2.
by the OP replacing the exact o2 that is currently on his car, he will have no problems. i'm taking it he had no problems with it after the swap.
Old May 22, 2007 | 02:01 PM
Relic1's Avatar
most honda 4-wire O2 sensors are the same so it really doesn't matter.
But generally speaking it is best to match the O2 to the ECU.
Old May 22, 2007 | 02:43 PM
FalkenSiR's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">most honda 4-wire O2 sensors are the same so it really doesn't matter.
But generally speaking it is best to match the O2 to the ECU.</TD></TR></TABLE>
Thank you.
Obviously, if he has an obd2 ls, then yea he'd be looking to get 2 o2 sensors. You match the 02 sensor to the obd of the ecu, if not the exact application for the engine.
Civic_4life
Oct 24, 2011 09:17 AM
slowej1
Aug 3, 2007 06:29 PM
Darkane
Mar 28, 2004 06:03 PM
boywonda
Sep 21, 2003 10:05 AM
fiftee_su
Jul 28, 2003 09:55 AM
