Burning oil questions
Old May 21, 2007 | 05:49 PM
del_orson's Avatar
Default Burning oil questions
Ran a B16 a year ago, never burned oil. Put the head on a B20 and burned oil on decel. Thats fine, I pulled it a part and honed the cylinders quickly and replaced the rings, still smokes. I never checked taper wear on the cylinders, due to the customer was not going to do anything about it anyways. Any ideas onto what it could be. But anyways, we boosted it at 9 psi now, she really burns the oil now, but that didnt supprise me anyways.
Old May 29, 2007 | 09:01 PM
HatchSpeeD's Avatar
stock pcv?
Old May 30, 2007 | 06:13 AM
4g hatch's Avatar
b20 has a bad rod to stoke ratio causes cylinders to wear out of round more.what rings did you use did you clock them
Old May 30, 2007 | 08:36 AM
Golden Eagle's Avatar
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">b20 has a bad rod to stoke ratio causes cylinders to wear out of round more.what rings did you use did you clock them</TD></TR></TABLE> i don't know ware you got that from but you are incorrect the only problem the b20 has is a week sleeve but he is not having a problem there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">Ran a B16 a year ago, never burned oil. Put the head on a B20 and burned oil on decel. Thats fine, I pulled it a part and honed the cylinders quickly and replaced the rings, still smokes. I never checked taper wear on the cylinders, due to the customer was not going to do anything about it anyways. Any ideas onto what it could be. But anyways, we boosted it at 9 psi now, she really burns the oil now, but that didnt supprise me anyways.</TD></TR></TABLE> most of the time the stock sleeve will go out of round and if you just did a hone and changed the rings its not going to help what needs to be done is go 20 over pistons and it will be fine
Old May 30, 2007 | 09:33 AM
4g hatch's Avatar
Default Re: (Golden Eagle)
http://hondatuningmagazine.com....html
this will explain it better
Old Jun 9, 2007 | 04:34 AM
del_orson's Avatar
Ok, I used a cheap set of ebay rings, and yes I did clock them. I wasnt burning oil at first, but after a month, it sort of started again. When I boosted it, It is really bad now. I think that it is the cylinder ware. I had a problem witha mustang having to much taper wear and it burned oil on decel. We are just going to get a new block, the guy that owns the car dont want to spend the money building the motor this time round. Thanks for all the help guys
Old Jun 11, 2007 | 07:16 AM
4g hatch's Avatar
i prefer oem rings but alot of people are happy with hastings. u could just bore the cylinders and get the rs machine type r knock offs
Old Jun 11, 2007 | 07:55 AM
its a turbo block, those are high compression pistons, they Will not work for him.
Old Jun 11, 2007 | 08:04 AM
4g hatch's Avatar
depends on how many pounds of boost
Old Jun 11, 2007 | 11:39 AM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">b20 has a bad rod to stoke ratio causes cylinders to wear out of round more</TD></TR></TABLE>
if that were the case, this would apply to all b18a/b's. b18c r/s ratios arent much better either. and they dont seem to have any problems.
Old Jun 11, 2007 | 12:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote">depends on how many pounds of boost</TD></TR></TABLE> no it does not depend those are all motor pistons.
Old Jun 11, 2007 | 12:59 PM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
if that were the case, this would apply to all b18a/b's. b18c r/s ratios arent much better either. and they dont seem to have any problems.</TD></TR></TABLE> thanks i was not going to wast time with him
Old Jun 11, 2007 | 07:01 PM
4g hatch's Avatar
you dont have to waste my time on me i guess the experts that deal with it every day dont know what they are talking about. more sideload to the cylinder walls will cause more wear.it wont be over night but it will happen. ive seen guys run a thicker head gasket on b16's,type r's what ever as long as it isnt alot of boost and have a good tune
Tyler B
Oct 1, 2015 05:33 AM
B0Z0
Jan 19, 2011 07:53 PM
aych2h
Feb 7, 2007 08:22 AM
lowRIDAH
Oct 20, 2005 11:36 PM
