Speedometer Goin Crazzy
Hey can someone help me??? I have a 92 honda civic I just replaced my axles and tranny seals and i was driving down the road goin about 70 and my speedometer was goin nuts could this be because of low tranny fluid??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jattek »</TD></TR><TR><TD CLASS="quote">your speedo cable might be damaged, due to you had just worked on the trans. And is this happening all the time </TD></TR></TABLE>
Speedo cable?
There's a green (i think it's green) wire from your vss going into your firewall, make sure it's connected correctly.
Did a shop do the work or was it DIY?
Speedo cable?
I had this problem arise with me i just had to replace the speedo cluster due to very high resistance on 1 of the coils.. i dont know what the specs are. to keep cost low for the moment take a friends cluster hook it up and see if you have the same problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jattek »</TD></TR><TR><TD CLASS="quote">I had this problem arise with me i just had to replace the speedo cluster due to very high resistance on 1 of the coils.. i dont know what the specs are. to keep cost low for the moment take a friends cluster hook it up and see if you have the same problem.</TD></TR></TABLE>
I would do that.
I would do that.
pin0y209
10
Jan 16, 2008 07:56 AM
BigDawwg6969
Feb 25, 2006 05:35 PM
