01 clutch squeaks
Old May 21, 2007 | 03:30 PM
blue01EX's Avatar
Default 01 clutch squeaks
Old May 21, 2007 | 07:08 PM
JimBlake's Avatar
Default Re: 01 clutch squeaks (Mac86)
The bottom picture IS the slave cylinder. It's piston rod pushes against the throw-out lever. That white plastic thing is like a ball & socket to push the lever. Have someone work the clutch pedal while you watch the lever...
Some cars have a big rubber bellows over that, but some don't. Try greasing it. That silicone spray goes away after a day or so (as you discovered).
If that doesn't do it, there's other possibilities that take much more work. Worst I suppose is the throw-out fork's pivot. You can't really reach it from outside...
jerzeyjoe
Jun 4, 2010 02:50 AM
D16Clunkin
13
Dec 22, 2006 05:43 AM
animated_life
May 20, 2004 01:38 PM
FK00GSR
Aug 3, 2003 06:33 PM
