Clutch acting up!!!
Clutch acting up!!!
Hey everyone, everytime I let my clutch out I hear a clicking sound (Metal or Plastic not sure). So i figured ill spray some WD-40 down there and it went away for a day and then comes back. Does anyone know what this could be? Please help it is really annoying. It clicks almost at the point where your clutches catches when letting out.
Re: Clutch acting up!!! (FK00GSR)
Have someone work the clutch pedal while you listen under the hood. It might actually be the slave cylinder piston rod or something like that, & the sound just travels back to the pedal.
Maybe grease the ball & socket in that rubber boot at the slave cylinder?? If it's really at the clutch pedal, try some grease instead of WD40. It'll last longer.
Re: Clutch acting up!!! (redlinegsr)
ok i found out that it is the master clutch cylinder. i am not sure if i need to take it apart and grease it up and reinstall or if i need a whole new one. If i do need a new one do you think its worth getting it from the dealer or should i get one at a junkyard. Actually are junkyards really that much cheaper then the dealership?
Re: Clutch acting up!!! (vtecivicex)
Does anyone know where I can find out how to replace this. Is there anyway websites on how to's. I already tried the search feature as well as team-integra.net Would the Helms manual help anybody.
DenisR
02-19-2016 05:09 PM
