OEM LSD and GM sychromesh = ok?
Is the OEM LSD compatible with GM synchromesh transmission fluid? I have the infamous 3rd gear grind under load....just making sure i'm not going to mess up my LSD diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beyond-redline »</TD></TR><TR><TD CLASS="quote">Is the OEM LSD compatible with GM synchromesh transmission fluid? I have the infamous 3rd gear grind under load....just making sure i'm not going to mess up my LSD diff. </TD></TR></TABLE>
i recommend honda MTF (so does your dealer). never had a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
i recommend honda MTF (so does your dealer). never had a problem.</TD></TR></TABLE>
I agree, the new MTF even has an updtated formula with friction modifiers of it's own.
I did use oem honda fluid. I just read on the boards here that synchromesh helps with worn sychros. I'v used it before with my dsm and nissan and liked the results. Oh well guess i need to pull the trans and fix 3rd.
shifts
Texas -OK -LA (Sales)
62
Oct 17, 2007 10:03 PM
