N/A BUILD...FUTURE MAYBE TURBO?
Old May 21, 2007 | 12:48 PM
R-Civic's Avatar
Default N/A BUILD...FUTURE MAYBE TURBO?
hey guys, i drive a EK4 B16A2, most effective parts are the header and catback. mainly stock.
My questions is,
im planning on the edelbrock performer X IM, with the TB (65MM).
Now im busy with an N/A build and maybe in a couple a years ill boost it up.
for street/strip applications.
1. Can i keep this IM, TB setup and use this untill future boost plans.
2. Can i use a bigger size setup for N/A build, 70 or 75 MM
i would be glad with some answers! THANX...
Old May 21, 2007 | 01:18 PM
kpowerdhatch's Avatar
Default Re: N/A BUILD...FUTURE MAYBE TURBO? (R-Civic)
Are you going to be running bigger cams and upgraded vavletrain?
70mm TB on your almost stock setup will do nothing.
Old May 22, 2007 | 11:24 AM
R-Civic's Avatar
Default Re: N/A BUILD...FUTURE MAYBE TURBO? (kpowerdhatch)
yeah...sorry i forgot...thought about BC camshafts, valvetrain & some head work
like valve seat cut & Set length adjusting, valve guide change & reaming, port polish, IM flowing etc...
Old May 22, 2007 | 11:39 AM
kangaroo's Avatar
If your going to boost it later then don't waste money on the N/A stuff..........because you'll just replace almost everything again.
Old May 23, 2007 | 08:28 AM
R-Civic's Avatar
Default Re: (kangaroo)
you know...that's runnin' round my head for a while.
i was also thinking about inproven my suspension, handling first...than save some money aside for the turbo setup.
Old May 23, 2007 | 12:13 PM
2ltrtodd's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-Civic &raquo;</TD></TR><TR><TD CLASS="quote">
1. yes
2. it will do nothing unless its fully built and 70mm would be fine. 75= way to big.
JDM_ego2033
Jun 14, 2019 12:53 PM
Dutch-VTEC
Mar 12, 2006 09:11 PM
the4ork
Jun 14, 2005 06:18 PM
athoughts
May 8, 2005 01:46 PM
ludesleep
Jun 12, 2003 06:25 AM
