Gsr parts into a d16y8?
Old May 21, 2007 | 12:16 PM
team 15's Avatar
Default Gsr parts into a d16y8?
Can I install gsr injector into a d16y8? Will it make some power cause i installed gsr throttle body into the d16y8 too? After i put the gsr throttle my car is alot stronger cause the gsr throttle is bigger than my stock ex throttle plus gsr fuel filter. What other gsr parts can I install?
Old May 21, 2007 | 12:23 PM
sicones's Avatar
Default Re: Gsr parts into a d16y8? (team 15)
nothing, stop waisting your time, go find how to turbo your car
Old May 21, 2007 | 12:26 PM
team 15's Avatar
Default Re: Gsr parts into a d16y8? (sicones)
I already have a jrs supercharger for my d16y8, but don't want to install it yet.
Old May 21, 2007 | 12:30 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team 15 &raquo;</TD></TR><TR><TD CLASS="quote">I already have a jrs supercharger for my d16y8, but don't want to install it yet. </TD></TR></TABLE>
Let me guess, you got a supercharger to be different?
You can't just add more fuel and get power, it doesn't work that way.
I suggest you grab an encyclopedia and look up "internal combustion engines"
Once you've read that, then get back to me.
Old May 21, 2007 | 01:05 PM
hatchnideas's Avatar
if i remember, the gsr has 240cc injectors... the d16y8 also has 240s...
that throttle body that you swapped most likely did very little for your performance, and the fuel filter .... lol typical placebo effect. hmmm how about you just buy a gsr engine swap?
Old May 21, 2007 | 01:06 PM
Sundown's Avatar
..or maybe he auto-x's...
OP: Did you port match the IM?
Ek Forever y0!
Default Re: Gsr parts into a d16y8? (hatchnideas)
I agree, The throttle body being bigger will probably help a little with throttle response, but nothing to write home about.
And I forgot, I think the injectors are the same size too. Small engine is a small engine
Old May 21, 2007 | 05:19 PM
doood's Avatar
been there done that
Default Re: Gsr parts into a d16y8? (ek forever guy)
it's all in your head
your stupid ricer head
MIBPreacher
Nov 6, 2012 08:27 AM
tougeEGsies
Aug 23, 2006 09:23 PM
EGhatch33
Jun 13, 2006 09:53 PM
AB16A2T
Nov 11, 2002 07:52 PM
