What ya thinking?? B20 Vtec build up.....
A friend of mine built up his Integra Type-R
Here are some facts:
CP Pistons, 84mm, with rings -(12.5:1 Compression)
Eagle rods
B20 Eagle Crankshaft
Cometic Headgasket
ACT Heavy Duty Pressure Plate with Street/Strip Disc
ARP Headstuds
B20/Vtec Golden Eagle Conversion Kit
Supertech Dual Valve Springs and Ti Retainers
Supertech valves
Hondata S100
Completly built head with stock ITR cams, ITR throttle body and a ITR intake manifold
2,5" header with a complete 2,5" Invida exhaust system
Comptech intake
Prelude H22 injectors
250hp on the Dyne.
But my friend said to me that the engine isnt running good.
14,5 sec on the 1/4 mile
What is the normal time on the strip with that kind of setup?
And is it possible that the setup on the ECU will not work correct??
Thanks for answering
Greetings from germany
Eagle rods
Cometic Headgasket
ARP Headstuds
Supertech valves
Hondata S100
Comptech intake
250hp on the Dyne.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wuman »</TD></TR><TR><TD CLASS="quote">Ok thanks.
Another question:
what will be a good 1/4 mile run for a EG hatch with a stock B16B engine, toda flywheel on 15" rims</TD></TR></TABLE>
SEARCH!
Another question:
SEARCH!
Another question:
what will be a good 1/4 mile run for a EG hatch with a stock B16B engine, toda flywheel on 15" rims</TD></TR></TABLE> 13.0 or you cannot drive.
Another question:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> 13.0 or you cannot drive.</TD></TR></TABLE>
lol
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption »</TD></TR><TR><TD CLASS="quote">I dont know what his setup is because 250hp is a lie.
With ITR cams on that compression and displacment, you should be happy with 205-210hp, but even that is strecthing it.</TD></TR></TABLE>
thats what i thought.
maybe hes squeezing ?
my friends ls-vtec w/ buddyclub 4 cams didn't make more then 220whp.
jdmoutkast
Aug 21, 2005 11:31 AM
texasSI
Apr 10, 2003 03:17 PM
something isnt right.
