Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Replacing Rotors on 1999 TL?
Old May 21, 2007 | 11:42 AM
Sporty2222's Avatar
Default Replacing Rotors on 1999 TL?
Hello!
Been reading posts here for awhile and now finally decided to post. This is a great place for info!
I know the wifes TL needs front brakes BADLY! The pads are pretty much toast, so I fairly certain the rotors are beyond being turned or cut. Replacing the pads doesn't bother me, but the rotors does. How difficult is it to remove the rotors after pulling the old pads? Any big or special tools needed to do this? I have replaced pads on an accord before and it was pretty straight-forward, but I didn't have to do the rotors. I cringe at taking to a local shop even though they are excellent and have always taken care of me. I would rather spend the 2-3 hours doing it myself and save the labor charge this time around.
Any help or insight would be great! (I guess I could also go buy the manual and see what it says!!)
Old May 21, 2007 | 02:10 PM
Kenso's Avatar
HT White Ops
Default Re: Replacing Rotors on 1999 TL? (Sporty2222)
Once you remove the caliper and caliper bracket, all you need to do is remove the 2 phillips head screws that hold the rotor on. You will probably need an impact driver for this (pictured below). Once the screws have been removed the rotor should come right off, or if it's rusted in place you might have to tap it with a hammer a few times to break it loose. Very easy to do yourself.
illusion
11
May 27, 2007 03:32 PM
Mrfeee1
Sep 1, 2004 09:54 AM
daewonder.
Mar 9, 2004 06:48 PM
90AccordEX4Dr
Sep 8, 2003 07:02 PM
deviant1
Dec 21, 2002 04:21 AM
