EJ drum-to-disc
Old May 21, 2007 | 09:43 AM
secondhandloser's Avatar
Default EJ drum-to-disc
So, I'm looking at doing a drum-to-disc conversion on my EJ8, and have a few question before I actually undertake the project. On EG's, the process is pretty simple, as you just drop in everything from an Integra, but 'teg LCA's won't work with the EJ rear suspension. Do I need to pull the setup from an Em1, or is there a way to make the integra suspension work?
Old May 21, 2007 | 10:30 AM
BlueIntegraBoy's Avatar
Default Re: EJ drum-to-disc (secondhandloser)
Pull your trailing arm assemblies from either an Integra or Civic Si, just reuse your stock LCAs.
Old May 21, 2007 | 12:10 PM
Default Re: EJ drum-to-disc (BlueIntegraBoy)
will everything bolt up OK? because I really don't want to buy the parts and not have everything work out right...
Old May 21, 2007 | 12:49 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
you dont need LCAs. you just need the trailing arm assembly. And the e brake cables from a 99-00 si. i've done tons of rear disc conversions. I've done both the GSR and the CTR conversion on a couple of my cars. EG and EK ....man i miss my EK.
Old May 21, 2007 | 01:03 PM
EL Vap133's Avatar
Just use your stock LCAs.
Old May 21, 2007 | 01:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by secondhandloser &raquo;</TD></TR><TR><TD CLASS="quote">will everything bolt up OK? because I really don't want to buy the parts and not have everything work out right...</TD></TR></TABLE>
Yes, it will
92hondaswap
13
Dec 27, 2012 05:03 PM
hondaOchibi7
Mar 9, 2011 10:23 AM
818SpoonITR
Nov 1, 2006 12:06 PM
Adrenaline_Racing
Nov 9, 2005 04:24 PM
K24EK
Suspension & Brakes
Sep 23, 2005 06:14 AM
