How much difference do pearls have on a base coat?
Old May 21, 2007 | 09:14 AM
R-Toyz.com's Avatar
Default How much difference do pearls have on a base coat?
I'm thinking about having a pearl coat done over a color base (not black or silver base).
How much difference will it have on the base?
For example, if I were to shoot a black pearl on a green base coat...do I end up with black? Or will the green still come out at certain angles?
Or if you shot a silver pearl over green, would you get silver? Or still get green with some silver shimmer on it at certain angles?
Old May 21, 2007 | 10:01 AM
WihaSi's Avatar
Default Re: How much difference do pearls have on a base coat? (R-Toyz.com)
The pearl mid-coat is very transparent and you would only be putting 3 coats of it on. So basically whatever base color you have will show. I'm sure you've seen Cadillac or Lexus's pearl white. It's a white base coat, with a white pearl mid-coat, the white shows through and mica flake in the mid coat gives the pearl effect. Personally I've never done any custom painting so I've only painted factory tri-stage, but knowing how transparent the mid-coat is, I'm sure whatever color your base coat is will show.
Edit: I'm not absolutely 100% sure on this
Modified by WihaSi at 2:42 PM 5/21/2007
landon.alder
42
May 26, 2010 07:51 PM
Westboarder
Paint and Body
Feb 7, 2008 04:23 PM
Yaa
Oct 12, 2005 10:21 PM
Madrek
Nov 8, 2004 01:30 PM
Soon_2b_evil
May 19, 2004 02:12 AM
