Painting white
Old Feb 7, 2008 | 10:35 AM
Westboarder's Avatar
Default Painting white
I have a white 95 Accord. Most of the replacement parts come with a black primer job. I was wondering if White goes well on top of black primer? Need advice from experienced painters.
Old Feb 7, 2008 | 12:28 PM
powerflow's Avatar
Default Re: Painting white (Westboarder)
If your using products from a professional auto paint system, just use a white sealer or a tint-able sealer, tinted with white toner before the base. Use a black or checkered spray-out card to ensure you have full color coverage before you clear. If your not really familiar with painting and color matching using a spray-out card will help to confirm you have full coverage and a good color match. With sealer you should have full coverage in 3-4 base coats if your color covers decently. Also make sure to use a flex agent if its available and make sure you choose the correct color variant that best matches your adjacent panels, fenders/hood.
If your using spray cans, just try to mimic these steps the best you can.
Old Feb 7, 2008 | 02:09 PM
swappedcx's Avatar
Default Re: Painting white (powerflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow &raquo;</TD></TR><TR><TD CLASS="quote"> Also make sure to use a flex agent if its available .</TD></TR></TABLE>
Why would you want to use a flex agent? Especially if its a part that is fixed like a fender and such, its a waste of material. Plus, I don't really believe in flex agents. Most flex agents will keep a part flexible for 90days...or around there, in my experience.
Old Feb 7, 2008 | 04:23 PM
powerflow's Avatar
Default Re: Painting white (swappedcx)
Why would you assume I meant parts other than bumpers?
It's very clear he is talking about replacement parts, not fixing a fender.
Bumpers are a common replaced part. Most Honda bumpers, OEM and aftermarket come in a black primed finish. I should have mentioned" if painting bumpers " or " if applicable" its pretty obvious flex agents are only meant to be used on flexible parts like bumpers. I agree that todays urethane enamel paints are very flexible and its definitely not an absolute must when using quality paint. But its still good advise.
landon.alder
42
May 26, 2010 07:51 PM
gore^bea
Paint and Body
10
Sep 25, 2007 01:19 AM
chinkcity07
Paint and Body
Aug 6, 2007 04:59 PM
Soon_2b_evil
May 19, 2004 02:12 AM
ekferio
Sep 27, 2003 01:34 PM
