integra rear disc brakes?
Old May 21, 2007 | 07:21 AM
mach0's Avatar
Default integra rear disc brakes?
i have a 96 ex coupe and i am swapping integra rear disc brakes on it...i had a 96 four door civic and i upgraded to si rear disc and they bolted right on to the same control arms...is this the same for the integra rear discs? if i use the integra rear disc brakes, would there be an issue using the struts from the civic??
Old May 21, 2007 | 07:25 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: integra rear disc brakes? (mach0)
You'll ned the rear integra trailing arms. You've already got the appropraite brake lines.
You've already got discs back there? why the change?
Old May 21, 2007 | 07:27 AM
mach0's Avatar
na...my old car i used si rear disc and it was a charm...they stole and stripped it...now i got a coupe...w/drums
Old May 21, 2007 | 07:32 AM
Ek Forever y0!
Default Re: (mach0)
Suspension/Brakes:
https://honda-tech.com/zerothread?id=152884- Putting X Brakes on Y Car
https://honda-tech.com/zerothread?id=514109- 96-97 JDM ITR 4 Lug Brake Information
https://honda-tech.com/zerothread?id=811892- ITR 4 Lug onto EK
https://honda-tech.com/zerothread?id=514109- ITR Brake Thread
https://honda-tech.com/zerothread?id=333061- Five Lug Conversion
https://honda-tech.com/zerothread?id=1036267- GSR Suspension into EG
https://honda-tech.com/zerothread?id=812062- Integra Rear Discs onto EG
https://honda-tech.com/zerothread?id=820484- Full Brake Swap for EG
https://honda-tech.com/zerothread?id=641639- EK Rear Disc Conversion
https://honda-tech.com/zerothread?id=1513752- How to put X Brake Setup on an EK
https://honda-tech.com/zerothread?id=641639- Complete Rear Disc Brake Conversion
https://honda-tech.com/zerothread?id=1030365- Integra Brake Swap
JDM_NANO
Northeast (Sales)
Oct 12, 2011 06:57 AM
wlp2nd
Suspension & Brakes
Nov 2, 2009 03:14 PM
crazy irishman
Oct 14, 2009 11:32 PM
SkyliteCustomz
Jun 28, 2007 03:59 PM
pootie.teng
22
Jul 12, 2006 07:27 PM
