how to get rid of a cel from turbo
you should ask this in the FI section but if you are running over 11psi I believe then you will throw the code for the map...ideally you should convert to a 2.5 or 3 bar map sensor but you can use a check valve system to bleed off the boost or use one of the missing link things...just do a search on here and you should be able to find info about it...
If you are not using any boost code on the ecu then yes the ecu will throw a map cel once its sees like 1.3psi,I bileve.... Yes you can put check valves between the map and vac source, but i recomend going with some real ecu tuning ie hondata, uberdata etc or if you are still obd0 then turbo edit
silverCRXTC
Feb 4, 2004 07:32 AM
VTgringo
Aug 19, 2003 05:01 AM
