Which TB is best for the B18B Skunk2 Mani.?
Old Jun 2, 2002 | 12:54 AM
2G0S0R1's Avatar
New User
Default Which TB is best for the B18B Skunk2 Mani.?
With 62403's w/Springs+ret. and a 8k redline... Im thinkin the stock ls is gonna hold back!!!
What will fit the manifold that is better?
Old Jun 2, 2002 | 04:16 AM
non-VTEC's Avatar
Default Re: Which TB is best for the B18B Skunk2 Mani.? (95LSRamAir)
you can use the stock T/B if you want or send it to a good machine shop and have them bore it out.
Old Jun 2, 2002 | 07:45 AM
broke1's Avatar
Default Re: Which TB is best for the B18B Skunk2 Mani.? (non-VTEC)
i thought eriks(sp?) racing had a nice tb out for around $350-$400
Old Jun 2, 2002 | 08:01 AM
non-VTEC's Avatar
Default Re: Which TB is best for the B18B Skunk2 Mani.? (broke1)
i'm sure they do but for about half that price you can have your stock T/B bored out and it will do the exact same thing.........
Old Jun 2, 2002 | 08:10 AM
Integra_Boi's Avatar
New User
i can't figure out whats wrong with my skunk2 manifold install.. installed it and now my idle keeps moving up and down... maybe i need a bigger throttle body?
Old Jun 2, 2002 | 08:16 AM
NotQuiteJdm's Avatar
Default Re: Which TB is best for the B18B Skunk2 Mani.? (Integra_Boi)
are you sure you connected that one little hose? my idle went up and down when this little hose came off..
Old Jun 2, 2002 | 08:39 AM
Tweakmeister's Avatar
check for leaks...and also check your idle screw.
Old Jun 2, 2002 | 09:05 AM
zilverz's Avatar
I have the same problem ... but mine is from a warped Intake Manifold .... water came through the intake manifold into the #1 cylinder ... rebuilt the engine ... but the #1 intake runner is slightly warped so it doesnt but up perfect against the OEM intake manifold gasket ...
to test yours for the same type of leak ... get a little WD40 ... have a friend rev the engine ... and spray it near the gasket ... if there is a leak .. it will suck the WD40 right in .. shut the car off ... and either double up the gasket ... or get a new intake manifold (:
could be the Throttle screw too ... adjust it and see if it makes a differece... ummm lets see as for the Throttle body ... LS throttle body is 58mm you can get a brand new Holley 62mm or 68mm throttle body for like $360 3 diff colors ... and sell your old one on EBay ... check the intake manifold specs to see how big a TB it can take without getting it machined
Old Jun 3, 2002 | 12:25 PM
New User
Default Re: Which TB is best for the B18B Skunk2 Mani.? (zilverz)
what little hose?
Feb 21, 2011 07:03 PM
matt_pound
Dec 3, 2006 07:16 PM
snowblind7x
Jul 12, 2006 06:52 AM
bobukler
May 29, 2006 08:50 PM
germanEE8
Feb 25, 2004 08:56 AM
