skunk2 manifold help
Old Dec 3, 2006 | 11:22 AM
matt_pound's Avatar
Default skunk2 manifold help
ok, we have a 97 gsr, just put on a different stock head and a skunk2 manifold
the car idles at 4K and kinda surges
if you hold your hand over the TB it will idle down to like 2K
and iv'e noticed from pictures of the skunk2 TB that it has a smaller hole to let in less air at idle (i guess due to the manifold not having secondaries)
would this be part of the problem, should i just get a skunk2 TB and see if that helps
anybody on here used a skunk2 manifold on a gsr
Old Dec 3, 2006 | 12:14 PM
Redline130's Avatar
Default Re: skunk2 manifold help (matt_pound)
I would look for a vacuum leak somewhere. Too be idling at 4K, there must be an open vacuum port or something. What t/b are you using?
Old Dec 3, 2006 | 03:14 PM
BILLY_BLING's Avatar
spray some strater fluid and if you have a leek at will rev up!!!
Old Dec 3, 2006 | 07:16 PM
matt_pound's Avatar
well i was using the TB that came with the head we bought
but i guess it had a fast idle valve on it
put back on the stock TB that did not have one
and the car runs fine
Mr.Fubbs
Aug 28, 2013 04:15 PM
gray89si
Feb 13, 2008 07:17 PM
AmauryR
Jan 5, 2003 08:50 PM
JDMkings
Oct 15, 2002 04:32 AM
SuperCivic
18
Oct 4, 2002 11:11 AM
