Oil light blinking
Just got a 2000 prelude 166,xxx km's. Its running 5w-30 Castrol Full synthetic. I was on the highway and opened it up. I was in 4th hitting vtec then the the oil light started flashing, so i immediately let off and the light went off shortly after, nothing over a minute. I took it easy the rest of the way home of course. The oil was at about 1/2 to 3/4's full. I am pretty stumped on this, i've read a couple threads but none that was like mine.
Also this has happened twice to me. I forgot to mention that. It happened the first time and then I filled the oil. Then a week later when i opened it up on the same highway the light came on and turned off.
I know there isn't any leaks because im on the driveway/ garage. Vtec for surely engages. Maybe the oil is too thick? Temperature is around 15-25 celsus outside and will be getting hotter in summer. I've always used 5w-30 all year around but maybe a different story for the Prelude?
I will be changing the oil tommorow because it looks a little dark.
Any help would be greatly appreciated.
Yeah i know oil light= low pressure. Ill try the changing the oil. The thing is do i go out and test it or what? Because i know at low pressure you can wreck stuff...
by putting 5 quarts in will it damage anything? right now i put 4 and a half and it is perfectly in the middle of the dots but i have had the light pop on during constant hard cornering but it stops after that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">If the pressure sensor goes bad will Vtec still engage? i.e. thre is a seperate pressure switch for Vtec to operate?</TD></TR></TABLE>
Thats a good question id like to know this also.
lilxvtecxpwr
Sep 4, 2003 10:51 PM
