VTEC Problem!?!
Old May 20, 2007 | 07:29 PM
accordingtoh22's Avatar
Default VTEC Problem!?!
Ok so i figured i'd put this here, move it if need be.
Here's what i've got
1992 Honda Accord with swapped JDM H22 w/JDM P13 ECU
so i'm having some trouble with my somewhat-recently swapped H22. It's a JDM H22, with a JDM p13 ECU. everything got wired in. (1 wire from ECU pin a4, to vtec solenoid,-- 1 wire from ECU pin d6 to vtec oil pressure switch, 1 wire from switch to ground)
The ECU throws a code for Vtec pressure switch (code 22)
so the pressure switch got replaced, ECU reset, wiring redone, grounds checked, and still has a code for pressure switch. as a result, vtec does not engage, and subsequently, rev limiter engages @ 6500, instead of 7800 rpms like it should....
i've been over my wiring like 5-6 times, so i don't see how it could be the problem.
i'm a little baffled, and i'm not sure what the problem could be. any ideas??
and the vtec solenoid does work, i wired it directy to switched 12 volts to test it.
Old May 20, 2007 | 07:54 PM
speedracer9k's Avatar
have you tried taking off the solenoid and cleaning the screen out. i had the same code and i cleaned the screen and cleared the code and i haven't had any trouble with it since
Old May 21, 2007 | 06:58 AM
Default Re: (speedracer9k)
i pulled the solenoid and it didn't look dirty or anything, what should i clean it with?
Old May 21, 2007 | 07:55 PM
i took mine out and put it into a bowl of carb cleaner. it will break up all the sludge inside the solenoid. just leave it soaking for about an hour. brake clean works just as well
darkbombers
Jan 21, 2012 01:42 PM
blackEGFTW!
Sep 4, 2009 04:25 AM
prime-R
16
Apr 11, 2009 05:33 PM
9WON4
Jun 2, 2006 06:11 PM
