crx with a b18a1 no start problem. need help
Old May 20, 2007 | 05:46 PM
bboy_mikey's Avatar
Default crx with a b18a1 no start problem. need help
so me and my friend got my crx running last week and i got to drive it around a bit but when i parked it, the car didnt start back up i'll turn the key and it'll crank but it wont start up as for parts i replaced the fuses, battery, alternator, starter, spark plugs, fuel filter, main relay, distributor, ecu, replaced all the grounds bolts. the car has gas, i can still hear the fuel pump prime when i turn the key half way, we checked for sparks and thats going good, we did a push start and that didnt start it. we think it could be a wiring problem but we're not sure cause the car turned on last week and drove just fine until i parked it....any ideas people?? or should i just take the car to a shop?
Old May 20, 2007 | 05:54 PM
Phils's Avatar
Default Re: crx with a b18a1 no start problem. need help (bboy_mikey)
check yer timin belt ?
Old May 20, 2007 | 05:56 PM
turbo1rx's Avatar
check the injectors maybe theyre stuck i had a problem today where my b18a1 didnt want to start we changed the ecu we did everything we could think of and then we hit the injectors and just like that it turned on try that maybe it will work.
fire_king
Engine Management and Tuning
Mar 8, 2012 02:45 PM
Pwnmeister
Aug 2, 2011 12:41 PM
EF909
27
Feb 27, 2010 01:30 PM
cbrracer91586
May 19, 2007 04:31 PM
Canonm7
May 19, 2005 09:28 PM
