Did LS/VTEC conversion and now low compression on all cylinders..
Bent the valves on the stock LS head after revving too high at the track, so I swapped on a GSR head with G.E. Vtec conversion kit(head gasket generously coated with copper spray), ARP studs, GSR water pump/timing belt, and ITR oil pump. After a day or 2 the engine started running rough so I did a compression test and got 130-140 psi on all 4 cylinders. I bought the head used so I might have gotten scammed on a shitty GSR head. Any ideas what can cause low compression on all cylinders? Also I found some weird white stuff on the out side of the sleeves where the water flows through.. Not sure what the hell that is.. Any ideas?
i had similar problems with my b16 and they told me that it was time to tear it apart and build it again. Do a leak down and see where your leaking compression. in my case it was my rings.
Block hasn't been resurfaced.. I really hope it doesn't need to be. I just got the haed back from the machine shop today.. They did a few pressure tests on it which all came back excellent, however they said the head was warped 1/8000th, so I had them deck it. Hopefully this will fix the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by base-op.1320 »</TD></TR><TR><TD CLASS="quote">Are you sure that it wasn't slightly off on timing causing valves to open to early and not allowing full compression?</TD></TR></TABLE>
point, if you're going to build it right. you must get it check out, Keep in mind that that's not a steel block. it's aluminum, it's just almost as bad as the head when it comes down to warpage.
crxowner
Mar 12, 2006 11:21 PM
