Side Skirts question (mounting)
Old May 20, 2007 | 01:02 PM
BlackHXCoupe's Avatar
Default Side Skirts question (mounting)
I was wondering if anyone has used anything besides the clips to mount the side skirts on. I'm talking about the OEM side skirts. Because all of mine fell off somehow and before I order them I'm making sure there isn't any other way I could go about doing so. Any help is appreciated, Thanks!
Old May 20, 2007 | 04:43 PM
NOFX's Avatar
H-T White Ops
Are you talking about the clips on the bottom or the clips on the inside?
Old May 21, 2007 | 10:46 AM
Default Re: (NOFX)
There aren't any clips on the bottom? The clips on the side holding them in. You slide the side skirt out/or in depending if you want it off or on. They all broke/fell off.
Old May 21, 2007 | 10:47 AM
nicko360's Avatar
* B A N N E D *
Default Re: Side Skirts question (BlackHXCoupe)
you can drill screw in there instead of using clips, that what i used for putting eks on my eg hatch
Old May 21, 2007 | 11:12 AM
NOFX's Avatar
H-T White Ops
6th gen sideskirts at least have white clips on the inside that hold them on, then screws at the ends and black clips underneath (that often rot form the elements and have to be replaced if you try to remove them).
Old May 22, 2007 | 12:33 PM
Default Re: Side Skirts question (nicko360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">you can drill screw in there instead of using clips, that what i used for putting eks on my eg hatch</TD></TR></TABLE>
I'll probably end up trying that out.
VTEC_PRODUCTION
Dec 8, 2007 10:51 AM
hale_image
Jan 8, 2005 02:14 AM
excel88
Jun 21, 2004 05:47 PM
sircrxracer
Jan 31, 2004 04:30 AM
