Side Skirts question (mounting)
I was wondering if anyone has used anything besides the clips to mount the side skirts on. I'm talking about the OEM side skirts. Because all of mine fell off somehow and before I order them I'm making sure there isn't any other way I could go about doing so. Any help is appreciated, Thanks!
Re: (NOFX)
There aren't any clips on the bottom? The clips on the side holding them in. You slide the side skirt out/or in depending if you want it off or on. They all broke/fell off.
H-T White Ops
6th gen sideskirts at least have white clips on the inside that hold them on, then screws at the ends and black clips underneath (that often rot form the elements and have to be replaced if you try to remove them).
Re: Side Skirts question (nicko360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 »</TD></TR><TR><TD CLASS="quote">you can drill screw in there instead of using clips, that what i used for putting eks on my eg hatch</TD></TR></TABLE>
I'll probably end up trying that out.
hale_image
01-08-2005 02:14 AM
sircrxracer
01-31-2004 04:30 AM
