problem with my mains...opinions...pics inside!
well i spun a bearing on this motor...i have another crank but not another block...now heres the thing...the mains like 2 or 3 of them have small scratches from the spun rod bearing...can this block be used??...i wouldnt want to hone the mains and then have to get different bearings...im not a fan of it...lmk ur opinions honda geeks and guru's....thanks ahead of time...pic
also this is the worst one others arent no where near as bad
Until you measure them you will not know if it junk or not. ERL has some .015 over mains that require a align bore and hone.
i measure them for him and they are in spec now...but by the time it gets bored and honed it def wont be...if the block was sleeved or was a gsr or type r it might have been worth it...but for a ls i dont think it is...he also already has std bearings
