Mount Fix
Old May 20, 2007 | 10:19 AM
95BoostedEJ1's Avatar
Default Mount Fix
anyone know what that stuff u can use to help stiffin a motor mount...i've heard some ppl talk bout usin it to help stiffin a mount or even a slightly damaged mount..anyone know?
Old May 21, 2007 | 12:43 AM
anyone?
Old May 21, 2007 | 06:34 AM
Civichatch2k's Avatar
Default Re: Mount Fix (ForcedSi)
Well with out knowing more information about a specific mount that you need to fix or stiffen.
All I can tell you is that you can order alot of mounts form innovative, hasport and I am sure there are some that I am forgetting.
Also energy suspensions makes inserts some stuff for mounts, but I have heard that they are not as good as a full mount replacement.
Old May 23, 2007 | 08:52 AM
my rear mount is the one thats busted...
Old May 23, 2007 | 08:59 AM
Frozen E's Avatar
H-T White Ops
You're talking about using window sealant to stiffen up the mounts. It'll work, but why not do it the right way since the thing is going to be out of the car anyway and replace it with a brand new urethane mount?
Old May 23, 2007 | 09:37 AM
delslo93's Avatar
Default Re: (IslandSi)
I just recently filled my mounts. I was told to use stuff called Window Weld and it is made by 3M and can be bought at Autozone. You will also need a caulking gun to apply it if you don't have one. Mine seem to be a bit stiffer and for only 15 bucks you can't beat it.
Old May 23, 2007 | 03:47 PM
Xscort's Avatar
same here, i just used 3M windoweld from autozone too. was like $13, doing the job though!!
Old May 25, 2007 | 05:04 PM
alright thx guys
Old May 25, 2007 | 05:13 PM
97Ej6mike's Avatar
New mounts, either OEM, or upgraded would make it feel better, also, Engine braces such as the Ingles "stiffy" work pretty well, lessens engine jerking and gives you a quicker response when you are shifting fast.
Old May 25, 2007 | 08:18 PM
well i sold the car yday so..my worries are over lol
lude98SH
Jul 8, 2007 08:34 AM
DB1_559
Jun 8, 2006 03:52 PM
HondaEF
Nov 20, 2005 10:22 PM
ITRswapandslow
Feb 12, 2004 01:51 PM
0554
10
Mar 5, 2003 10:29 PM
