Crack Block
My 2000 Accord has a crack on the block, oil going to the rad....
1st I thought its a head gasket, I did everything replaced HG, Machine shop told me no crack on the head.
now to fix the crack Block can I use product called Thermagasket by http://www.rxauto.com/
if anyone have more info about this please post.
Thanks in Advance.
Thanks in Advance.
please follow this thread, you'll know how its happened.
https://honda-tech.com/zerothread?id=1938162
F23 Block know to fail like this - near water jackets and oil passage.
but I had to learn the hard way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord380whp »</TD></TR><TR><TD CLASS="quote">buts thats not telling me what you did to crack a strong *** block . </TD></TR></TABLE>
All you have to do is read the thread...
It explains it all.
It explains it all.
I've experienced many motors at work with this issue...unfortunately, the best way to take care of the problem is to install a complete used motor from the start so you don't run into this same problem again...sorry about your headaches...
I don't have any experience with this product...but at this stage...it's worth a shot...
good luck,
AJ
good luck,
AJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord380whp »</TD></TR><TR><TD CLASS="quote">Am I blind ,what broke the motor. Am I that blind . Cuz I dont see anything stated why the block was cracked. </TD></TR></TABLE>
i dont see anything either.
basicly it's just a manufacturing defect.
