Engine rebuild cost??
Old May 20, 2007 | 04:41 AM
jdmkid8383's Avatar
Default Engine rebuild cost??
ok I have a b16 head and a b18a block I have been looking up parts on how much everything will cost to build it and its just sooo much How much would I be spending to get this motor rebuilt with parts, and machine work???
Im lost with what I should do.
Or should I just get a more up dated b18b non vtec and boost that It would be cheaper..
HELP ME OUT GUYS
Old May 20, 2007 | 05:04 AM
stumpyf4's Avatar
Default Re: Engine rebuild cost?? (jdmkid8383)
It's always cheaper to buy a swap and just drop it in. You just don't know what condition the motor is in until you run it for the first time.
Rebuild cost as follows:
Bore and hone: ~200
Pistons: ~150
Gasket kit: ~200
Head gasket: ~100
Main Bearings: ~70
Rod Bearing: ~75
Extras stuff that you don't account for like ARP main and head studs, head work, etc.: $$$
Labour for assembly is not included because you're doing all the work yourself, right!!
Old May 20, 2007 | 05:23 AM
jdmkid8383's Avatar
Default Re: Engine rebuild cost?? (stumpyf4)
This is the first time rebuilding it. I never installed pistions before is it hard?
Old May 20, 2007 | 09:31 AM
kartman5's Avatar
You may want to consider finding a rasonabally priced professional rebuilt so that
it gets done right the first time and you can avoid paying for the same thing twice.
I've had two engines rebuilt and the price wasen't bad and the engines have run
great without any problems. Just a suggestion and good luck!
Old May 20, 2007 | 11:32 AM
1.8L_allmotormilitia's Avatar
$2000?
Old May 20, 2007 | 11:34 AM
kartman5's Avatar
Default Re: (1.8L_allmotormilitia)
$2000.00 - $2500.00.
Old May 20, 2007 | 11:42 AM
jdmkid8383's Avatar
Default Re: (kartman5)
2000 not bad..
Time to robb the bank
Old May 20, 2007 | 01:02 PM
98BabiGs-T's Avatar
Default Re: (jdmkid8383)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmkid8383 &raquo;</TD></TR><TR><TD CLASS="quote">2000 not bad..
Time to robb the bank</TD></TR></TABLE>
That's not the final/exact price... they were only giving you an estimate. It depends if your gona be doing some work on your own or letting the shop hack and slash them. Plus it also depends on the shop's price/labor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kartman5 &raquo;</TD></TR><TR><TD CLASS="quote">$2000.00 - $2500.00.</TD></TR></TABLE>
Somewhere around there. -/+
boostedb20ek
Feb 25, 2010 03:10 AM
brandnewman16
Sep 25, 2007 07:30 AM
TurboEK9Coupe
10
May 8, 2007 03:52 AM
honda93
Jan 12, 2004 12:00 PM
navin
Jan 14, 2003 03:17 PM
