idle question
i have a built d16z6 in my 92 si hatch, when i start it the idle goes up and down between 200-900 but maybe its from my cam? also on cold starts when i start it and hit the gas it will stick to 1.5k till it warms then it will do the 200-900 rpm climb, also i have a b18b throttle body on the oem z6 manifold but i can find no leaks what so ever
also when i slow down for a light i press the clutch in and it stalls on me. i have a lightend fly wheel and 6puck clutch, i thought it was that accidently grabbying so i blead it alot and didnt help, i also cleaned the tb and IACV any other ideas on what to try? i'd really appreciate it
Modified by b_serious at 3:50 AM 5/20/2007
you probably need to replace the throttle cable same thing happend to one of my buddies when he ran a bigger TB... im just not sure if you need the b18 or a replacement... i would assume the b series.
im having the exact same problem.
similar setup as well.
the only difference is i have a skunk 2 im and a str 68mm tb.
i think the problem with mine lies in the TB.
im gonna change it back to stock in the next couple days and ill let you know if i find anything.
SO i think i've found the problem.. i unplug the IACV and it idles smooth at 650rpm.. i rev it and it drops back to normal with out stalling.. but doing this throw a CEL. how do i test the idle air control vavle?
JessumYessum
May 7, 2015 04:04 PM
jcfreibert
Nov 26, 2007 02:23 PM
baonest1
11
Oct 12, 2003 02:46 PM
