T3/T4 turbo??? too big?
I don't know a whole lot about turbos so I'm here to learn. My buddy is selling his T3/T4 turbo and manifold for a SOHC Turbo setup. He's offering it to me for like 200-300 dollars... should I get it?
Is the t3/t4 turbo good? He said it starts spooling at 3k.
Thanks
Thanks
depends on your goals for you set-up...
whats the trim size or gauge of the turbo?
how much power u want?
u using a stock block?
a t3/t4 is basically perfect for most stock block applications but just depends on what ur trying to do.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDaTurboTeg »</TD></TR><TR><TD CLASS="quote">depends on your goals for you set-up...
My goals are to have a quick little daily driver. Nothing specific, simple as that.
Yea I'm gonna be using a stock Y7 block with about 126,000 miles on it.
I'm not looking for an incredible amount of power but I want a nice increase.
If I do a mini-me before turbo would that give me more power in the end? I've heard mini-me's are kind of a waste.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDaTurboTeg »</TD></TR><TR><TD CLASS="quote">i think a nice t3/t4 48 trim .57A/R should be nice</TD></TR></TABLE>
Was going to agree, depending on the trim size it might work but I would not go to bog.
With a 3" dp and exhaust and small housing AR's, it would start producing some possitive pressure at 3k. But the last fully built d16 I saw with a t3/t04e 57trim took til 5k to hit 9psi.
Built, get a t3/t04e. Stock, get a t3. But for $200-300 for the mani and turbo, assuming the turbo doesn't need a rebuild, and that neither are ssautochrome parts (or similar chinese crap), jump on it.
You could try a mini-me, but from what I've seen, a t3/t04e will be more than enough to push the stock internals to the limits at 10psi with the y7 head. You could do the same with a T3 and a $15 2.5bar MAP sensor mod.
Modified by HiProfile at 9:41 PM 5/20/2007
yeah be very careful in buying things from "friends"
i had bought a turbo, mani, and wastegate from this kid that i thought was kind of a friend but......come to find out that this a-hole sold me a SSAC mani and wastegate, and some other cheap *** turbo......
i didnt know when i bought it because i really didnt know much about certain parts and what not....
def make sure its something real and good quality
