How much can 83mm stock sleeves hold
Old May 18, 2007 | 08:29 PM
Del Sol on Steroids's Avatar
Default How much can 83mm stock sleeves hold
Can it safely hold a 100-125 shot, or 10lbs of boost.
Old May 18, 2007 | 08:31 PM
Schister66's Avatar
Man U FTW
i didnt even know you could bore stock sleeves out that far.....
indicajones's Avatar
Default Re: How much can 83mm stock sleeves hold (Del Sol on Steroids)
10psi should be fine as long as its tuned right. its all in the tuning my good manor woman.
Old May 18, 2007 | 08:42 PM
Default Re: (Schister66)
why not 83, a b20 is 84 bore
Old May 18, 2007 | 08:45 PM
Default Re: How much can 83mm stock sleeves hold (indicajones)
I can get it tuned nicely, but I need it to last a couple of years as daily driver. Just need to know if they will hold up.
Old May 18, 2007 | 08:46 PM
A.E Motoring's Avatar
that comes stock on a b20, hope u dont plan on trying to bore out a 1.8 like that
Old May 18, 2007 | 11:36 PM
zexxbo's Avatar
Default Re: How much can 83mm stock sleeves hold (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol on Steroids &raquo;</TD></TR><TR><TD CLASS="quote">why not 83, a b20 is 84 bore</TD></TR></TABLE>
der der der
Old May 19, 2007 | 12:32 AM
tokesGTR's Avatar
Default Re: (Del Sol on Steroids)
B20 is a completely different sleeve design from the 81mm B18's. You can't "debore" a B20 to 83mm, nor could you bore a B18/B16 out to 83mm and keep any strength in the walls. You'll oval the cylinders in short order. Stick to anywhere from 81 to 81.5 bore on stock sleeves.
Old May 19, 2007 | 10:47 AM
Default Re: (tokesGTR)
then will a b20 hold it, well bored to 84.5 to resurface it
Old May 19, 2007 | 10:56 AM
nothing is guarenteed, and with stock sleeves your running a VERY big risk, and your wanting to bore to 84.5, the walls are not designed to take that much of abuse, if the motor goes lean there goes your motor, walls will crack, the thinner they go they becomg weaker, do your self a favor and sleeve it.
zexxbo's Avatar
you dont need to bore it. why not just run the stock bore?
Old May 19, 2007 | 11:03 AM
Default Re: (zeimbo)
well, at least hone it, to fix any out of round wear. But I'll just stick to the b18. save some money for other stuff
Old May 19, 2007 | 11:11 AM
well thanks for the feedback. I'll see if I can later on sell the b18c block to buy something sleeved.
Old May 19, 2007 | 11:15 AM
zexxbo's Avatar
if you want less than 450whp, you can get that with the stock bore on the b18c and stock sleeves. the only real benefit for you going to a larger bore would probably be more torque.
you can definitely do a hone on the engine without being worried but ask your mechanic or machine shop if the block even needs a hone. its never a bad idea tho.
3Rd GeAr PuLl
12
Feb 26, 2007 04:20 PM
allmtrdc4
Feb 21, 2006 06:30 AM
oem_dc2
Dec 26, 2004 09:05 PM
LSVTECoupe
Nov 5, 2003 09:31 AM
EVOLMTR
May 8, 2003 03:37 PM
