1994 civic ex won't crank!!!
Old May 18, 2007 | 04:33 PM
jayjay's Avatar
Default 1994 civic ex won't crank!!!
hey all,
I have just finished putting the motor in my civic. The previous owner had the head gasket blow out and hse drove it until it got so hot that the timing belt cover melted. Her husband took the head off and had it checked and resurfaced.
The block was cracked so I put in a 1993 d15b7 block.
Problem is....
Now that the car is back together and ready to go. It won't turn over. Almost like there is no power to the starter.
When I put the key in the ignition the (SRS) light comes on. Should it go off?
I have checked the starter. it works fine. I have checked the fuses. I have checked all the connections.
What could it be?
any help would be geartly appreciated.
Old May 18, 2007 | 04:36 PM
dave3231's Avatar
the srs light indicates that the airbag is active..
but about not starting..maybe a new starter
Old May 18, 2007 | 04:50 PM
Tomdata's Avatar
Default Re: (dave3231)
have you checked to see if the stater solenoid is getting power when you try to crank it? If so, its pretty simple. time for a new starter. if not, time to start figuring out why the power isnt making it from the ignition switch out to the starter.
Old May 18, 2007 | 05:54 PM
Mangotreemechanic's Avatar
Default Re: (Tomdata)
Same thoughts here. Need to troubleshoot from the starter back. Wear and tear could have affected relays and switches as well. Time to check each, one by one.
Old May 18, 2007 | 06:43 PM
youngbucker19's Avatar
push start it 2 see if everything runs nice
unless its an auto
Old May 18, 2007 | 06:47 PM
jayjay's Avatar
Default Re: (youngbucker19)
oh... your smart.
ok back to business.
starters out. If I jump power from the positive terminal.. to the spade connection... it should throw the solenoid.. right?
If so... I got a bum starter.
Old May 18, 2007 | 08:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (jayjay)
Check your main relay.
Is the fuel pump priming?
Are you getting spark?
Old May 19, 2007 | 06:18 PM
jayjay's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Check your main relay.
Are you getting spark?</TD></TR></TABLE>
umm.. the starter won't engage!!! so it really would'nt make any difference if I had spark or not..
Old May 19, 2007 | 06:46 PM
94c1v1cex's Avatar
go get a new starter...
Old May 19, 2007 | 07:08 PM
da_dude's Avatar
Check starter or ground.
Old May 24, 2007 | 03:39 AM
jayjay's Avatar
Default Re: (turb20_vtec)
I have found out why my car would not crank over. It was the large ground wire that runs from the frame to the tranny.
It seems that the previous owner had broken the bolt holding the ground wire. It looked visibly connected. When in fact it was just laying in place.
nestea8869
10
Mar 26, 2022 10:12 AM
Jeannies car
Sep 6, 2015 09:26 AM
seane51
Jan 17, 2014 03:50 PM
shogun88
Feb 28, 2012 11:28 AM
Dc295kid
Jul 2, 2009 01:34 AM
