How many o2 sensors on a 99 d16y8?
Quick question - how many o2 sensors are there on a 99 d16y8? I know there's one before the cat on end of the header but are there any others? I notice my car bogs a little bit at low RPM's and I've done a complete tune-up besides PCV valve and any other o2 sensors I may need to change. So if there is another o2 sensor, Ima swap that out soon. Motor has 178,300 FTL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 »</TD></TR><TR><TD CLASS="quote">So I'm guessing the 2nd one is the downstream one (after cat)?
Perfect
. Thanks</TD></TR></TABLE>
Actually, it's bolted into the catalytic converter.
Perfect
. Thanks</TD></TR></TABLE>Actually, it's bolted into the catalytic converter.
I like replacing things just for the sake of replacing. The upstream o2 sensor was never changed until 16x,xxx miles and the downstream one is still OEM with over 178k, on it. I just like replacing parts.
you can replace my broke *** by sending me the money instead of just replacing parts. If you feel the need to spend money, why not upgrade something that would benefit your motor and/or your car. Do something productive.
Replacing a part that has nothing...absolutely nothing to do with your motor performance-wise is stupid and you should have some sense knocked into your head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi »</TD></TR><TR><TD CLASS="quote">you can replace my broke *** by sending me the money instead of just replacing parts. If you feel the need to spend money, why not upgrade something that would benefit your motor and/or your car. Do something productive.
Replacing a part that has nothing...absolutely nothing to do with your motor performance-wise is stupid and you should have some sense knocked into your head.</TD></TR></TABLE>
Exactly. The dude can send me his old (and still working) o2 sensor so I don't have to pay to replace my bad one.
silentblackhat
Feb 15, 2005 10:33 AM
jdkornlp
Nov 7, 2003 09:38 AM
