help!!!! transmittion
Old May 18, 2007 | 09:29 AM
livebytheboard's Avatar
Default help!!!! transmittion
I have a 91 crx with a jdm b16 that i am loking to sawp into my eg hatch. but i noticed the g has a hydrolic clutch and the crx has a cable clutch, is there ne way i can still swap them with what i have as is?
Old May 18, 2007 | 09:39 AM
deadline's Avatar
just swap the tranny to hydro...u can sell the cable then buy a hydro..they go for about the same amount of money..
Old May 18, 2007 | 10:15 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (deadline)
Yep, you'll need a hydro b16 tranny for your hydro eg.
If you want to put the motor you have in you eg into your rex you'll need a cable tranny or switch it do hydro via a conversion kit. Which tend to get expensive.
Old May 18, 2007 | 10:16 AM
i cant just run the cable to my clutch pedal?
Old May 18, 2007 | 10:18 AM
Ek Forever y0!
Default Re: (livebytheboard)
A cable transmission shifts via cables from your shifter to your tranny essentially.
A hydrolic transmission uses a shift linkage and shifts via a slave cylinder which pressurizes fluid through the lines to engage the clutch/shift assembly.
Old May 18, 2007 | 03:57 PM
yeah but i was thinking of removing the master cylinder, since the slave comes off w/ the transmittion, then one i have the master removed i can run the cable on the other trans thru my firewall and attatch it to my clutch pedal. would that work?
Old May 18, 2007 | 04:48 PM
Ek Forever y0!
Uhhhh... Not really. I don't think your following.
it won't be compatible unless you buy a special conversion kit that has special mounts and brackets.
Bottom line, just save yourself the headache and get a hydro tranny.
Jdmek920
Jan 22, 2013 09:53 PM
DACteg
Feb 8, 2008 08:15 PM
lilo_goki
13
May 9, 2007 10:34 AM
xlusiveracer
Feb 28, 2005 02:32 AM
wilntegra
Jan 26, 2005 06:04 PM
