need some help...
Old May 18, 2007 | 05:15 AM
boosted_ef9's Avatar
Default need some help...
ok so i have a 90 civic cx and i decided to pull off the head to start a mini me swap...i took off dizzy battery and then the valve cover and undid like 8 head bolts...didnt mess with anything else and then something told me to wait so i decided not to do the swap anymore so i put the head bolts back on and then the valve cover and the dizzy hooked up the battery and started it it was mis firing (it was the firing order) so after like an hour of screwing around with it i figured out the firing order and no misfire...now the car cranks but it doesnt want to start i got new ngk blue wires and everything and now im stuck...i dont no what the problem is if anybody has any suggestions or knows wtf i can do lemme no im stuck and running outa patience...help wood b greatly appreciated...thanks
Old May 18, 2007 | 06:01 AM
Ilovemyef9's Avatar
Default Re: need some help... (boosted_ef9)
Maybe u blow your coil in the dizzy with all the cranking of the mis fire, check if the dizzy has spark if not it's your coil.
Old May 18, 2007 | 06:05 AM
Default Re: need some help... (Ilovemyef9)
noi have spark in the dizzy i checked yesturday night i dont no what to do now lol could it be anything else maybe the motor junk? bent valve? i dont no i had the firing order wroing and it barley started and i had to drive it back into my garage andi had to rev it to like 5000rpm just to move it lol it was making weird noises and smokeing blue and grey smoke
Old May 18, 2007 | 06:13 AM
ChickenH's Avatar
Did you put the ground wire back on ?
JDMflavor_EJ
Jun 2, 2007 08:52 PM
gxiang
Apr 30, 2007 06:50 AM
Metzler
Dec 20, 2005 12:08 PM
timsch75
Aug 22, 2005 07:31 PM
gtowni3
24
Apr 18, 2005 08:11 PM
