idle problem HELP ASAP!
i recently purchased a 1997 honda civic EX with a swapped b16a2 motor. when i first start the car the idle jumps up straight to 3 grand after several seconds it drops down to 1 grand to 2 1/2 grand and jumps up and down between those RPMS. help is appreciated! thanks in advance!
The Cars IACV (idle air control valve) is either clogged, or not functioning. It needs to be either cleaned or replaced.
The IACV is located on the back of the intake manifold, just to the right of the throttle body. Its not hard to get it, its in plain view.
It has a 2-wire plug going to it, and 2 coolant hoses beneath it. Its held on by two 12mm (i think? or 10 i dont remember) bolts.
Remove them, clean out the two ports on it, they gunk-up over time, or the unit needs to be repalced as a whole. When unit stops functioing, it causes the idle to lope between a normal idle (800 or so ) to as you said, about 2 grand or even more
Are you getting an CEL's?
hondachris1994
10
Feb 25, 2006 02:37 PM
