IGNITION HELP
Old May 17, 2007 | 02:24 PM
EGLUVN's Avatar
Default IGNITION HELP
I need to know where the ignition coil is and how to replace it. im lost
Old May 17, 2007 | 02:27 PM
yoffer's Avatar
Banned
Isnt it inside the distributor? If so i think you have to replace the the whole thing.
Old May 17, 2007 | 02:40 PM
EGLUVN's Avatar
Default Re: (yoffer)
i guess u just pull the cap and rotor. but not 100%
Old May 17, 2007 | 03:14 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (EGLUVN)
It's inside the distributor cap but if you don't know what to look for or how to fix it, buy yourself a good Helms manual and learn to do it yourself or pay someone to do it properly.
Old May 17, 2007 | 03:33 PM
Mr.EM1_EK's Avatar
Default Re: (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">It's inside the distributor cap but if you don't know what to look for or how to fix it, buy yourself a good Helms manual and learn to do it yourself or pay someone to do it properly.</TD></TR></TABLE>
yup, they are fairly easy though
Old May 17, 2007 | 03:45 PM
94hatchling's Avatar
they are really easy to replace. i just did mine yesterday.
if you use the search feature here, and search in the archives you can just about anything. here's the link for those that dont know how to replace the ignition coil....
https://honda-tech.com/zerothread?id=1430824
i'd replace the igniter (aka ICM) at the same time as well. even though its considerably more expensive.
have fun! if you're mechanically inclined, then it will only take you 30min TOPS. did mine in 15.
Old May 17, 2007 | 03:58 PM
MJ0LNIR's Avatar
Default Re: (94hatchling)
Make sure you install it back in correctly...I've done it
EDIT: saw from your sig you have a b-series, not sure if that's an issue or not, it is on my d-series
Old May 17, 2007 | 04:51 PM
Default Re: (MJ0LNIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJ0LNIR &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you install it back in correctly...I've done it
EDIT: saw from your sig you have a b-series, not sure if that's an issue or not, it is on my d-series </TD></TR></TABLE>
still comes apart the same and goes back together the same. just different part numbers.
to the OP:and the dizzy only goes back on one way. just make sure you mark it where it came off so you dont throw off your timing.
Modified by 94hatchling at 9:31 PM 5/17/2007
Old May 18, 2007 | 07:55 AM
EGLUVN's Avatar
Default Re: IGNITION HELP (EGLUVN)
Fixed the issue. I got a coil from schucks for like 62$ and switched it out in like 15 minutes
PhantomX
Jan 30, 2009 02:23 PM
Hybrid Invasion
Nov 25, 2007 11:50 PM
ActiveAero
Sep 16, 2006 11:21 AM
DredwerkZ
Apr 19, 2004 05:21 AM
joeymachado
Nov 13, 2003 10:48 PM
