Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
TDC interuption problems
Old May 17, 2007 | 11:35 AM
02casperaccord's Avatar
Default TDC interuption problems
i have a 2001 honda civic that keeps throwing a code of tdc interuption which makes the car run like total crap. Any Ideas?
Old May 17, 2007 | 11:41 AM
Boilermaker1's Avatar
Change the cam sensor.
Old May 17, 2007 | 12:07 PM
Default Re: (Boilermaker1)
already changed the tdc sensor and its still throwing the code.....any suggestions???????
Old Jun 1, 2007 | 04:18 PM
FIVESTARR*EM2's Avatar
Default Re: (02casperaccord)
try to change out your coils and spark plugs.
Old Jun 1, 2007 | 08:07 PM
skipbarber's Avatar
Default Re: (FIVESTARR*EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FIVESTARR*EM2 &raquo;</TD></TR><TR><TD CLASS="quote">try to change out your coils and spark plugs.</TD></TR></TABLE>
how would that help?
what P0 code are you getting specifically?
Old Jun 2, 2007 | 06:13 PM
Default Re: (skipbarber)
If you go to autozone to get a code check. my came out to be
P1362
Here is what the possible problems.
-Ignition Control module (ICM) bypass circuit low input
-Cylinder 3 Ignition Circuit Short to B+ Explanation.
-Misfiring during start cylinder 11
-TDC No Signal
-No signal in TDC 1 Sensor Circuit.
So it could be your coils or your tdc sensor.
Old Jun 6, 2007 | 02:40 PM
01nighthawkcivc's Avatar
well, its my civic and I have replaced all the coil packs and new plugs..... and now im getting an error code when trying to scan the computer..... it wont let me communicate at all...... what can i do?? please help
the mechanic that has it says the ground is ok and says that there is voltage where there shouldnt be in the wiring?? how would that be?
he said it measures 1.5 volts when there should be none any suggestions???
the cam backfires and wont respond under boost...the tachometer stopped working the temperature gauge stopped working and the battery light tends to come on and go off......but the alternator is brand new and so are all the belts and hoses as well as battery.
Old Jun 24, 2007 | 10:40 PM
Default Re: (01nighthawkcivc)
check fuel pump, fuel filter and tdc. I had the same problem. i replaced the tdc sensor, coils, plugs, fuel filters and now its working fine.
Old Jun 25, 2007 | 05:13 AM
anonnonator's Avatar
yes, definetely check your fuel pump. lol, i remember going through that ****. took forever. And no tech seemed to have an answer. Fuel pump wasn't working properly. voltage said everything was fine, but I checked it and it wasn't working. . Could be that problem, not saying it is. Good Luck.
jonney66
Honda CR-V & Element
May 6, 2014 01:24 PM
bLu92bUbbLe
Jul 10, 2008 12:57 PM
lax1089
Apr 19, 2007 11:02 AM
jdmazm
Apr 24, 2005 04:34 PM
