Which 2 gauges?
Old Jun 1, 2002 | 11:36 AM
YellowR2000's Avatar
New User
Default Which 2 gauges?
So i dont want to use the a pillar gauge pod so i was going to go with the gauge pod that replaces the plastic piece in front of the gauge cluster and behind the steering wheel but it only has a slot for 2, so for an all motor set up, probably will eventually go with spec b's and everything that goes along with it, which 2 gauges would be best for me to run? thanks.
Old Jun 1, 2002 | 11:55 AM
Pinhead's Avatar
New User
Default Re: Which 2 gauges? (YellowR2000)
I just got oil pressure and oil temp
Old Jun 1, 2002 | 11:57 AM
Tommy_Gunns's Avatar
Default Re: Which 2 gauges? (Pinhead)
I second that. A/F is a waste.
Old Jun 1, 2002 | 12:51 PM
Rob :190:'s Avatar
Default Re: Which 2 gauges? (Tommy_Gunns)
my ideal setup: Oil (temp and press) and water temp. i know thats 3 guages, but oh well
Old Jun 1, 2002 | 12:54 PM
Mike M's Avatar
Founding Member
I have one of these, I used to have the A Pillar pod and went with the Gauge surround so it wouldn't stick out as much.
IMO Its a cheesy piece of crap, The plastic is thin and bendable (Like a rubbermaid barrel) and it doesn't fit so great. I'm going back to the A pillar pod.
Old Jun 1, 2002 | 12:57 PM
Pinhead's Avatar
New User
Default Re: Which 2 gauges? (TypeRmsm)
damn it, don't say that I just ordered one
Old Jun 1, 2002 | 01:04 PM
New User
So the oil temp and pressure should do. one of my concerns is running to lean, ill have a VAFC so i dont want to make any changes and run lean and not know it <my friend did this to his lude, ran good times but didnt realize he was running lean> Any other suggestions?
[Modified by YellowR2000, 2:12 PM 6/1/2002]
[Modified by YellowR2000, 3:22 PM 6/1/2002]
Old Jun 1, 2002 | 01:13 PM
Rob :190:'s Avatar
if you tune the VAFC on the dyno, running lean wont be a problem
but yeah, oil temp and pressure are good guages to have
Old Jun 1, 2002 | 02:24 PM
New User
Default Re: Which 2 gauges? (Brian Spilner 1035)
Also i was wondering why would thosse 2 gauges be the one you would choose? i dont want somthing and not even know why i have it over another.
Old Jun 1, 2002 | 02:29 PM
Rob :190:'s Avatar
well we already have a water temp guage, but no oil pressure or oil temp, so thats one way to look at it. however, if i had to choose just 2, i'd do a oil temp and a water temp. from what i understand the factory water temp guages is a just a 3 position type thing, with 'cold', 'normal', and 'hot', IE, not too accurate.
Old Jun 9, 2002 | 06:10 PM
IntegraR0064's Avatar
How are you guys installing the temperature senders (for those with electronic gauges)?
integral94
Jan 28, 2007 12:16 AM
GSRswapandslow.
10
Jun 8, 2004 11:28 PM
teg92
Apr 24, 2003 10:40 PM
Tommy_Gunns
Dec 5, 2001 07:13 PM
IntegraR0064
Jul 2, 2001 09:08 PM
