Changing my gear ratio by changing my tires
Old May 17, 2007 | 08:12 AM
YipMan_Style's Avatar
Default Changing my gear ratio by changing my tires
I got 195/50/15 now. If I go with 195/55/15, the tires will be 10% taller.
Will that mean my gear ratios will be like 10% taller. Does that mean I will get better MPG?
I know about the speedo error, and I'm ok with that.
What do you think? Will I get better MPG assuming driving style remains the same?
Old May 17, 2007 | 08:16 AM
dpaton's Avatar
Default Re: Changing my gear ratio by changing my tires (YipMan_Style)
You're effectively changing the final drive ratio by doing that, not the individual gear ratios.
Old May 17, 2007 | 08:19 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Changing my gear ratio by changing my tires (dpaton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpaton &raquo;</TD></TR><TR><TD CLASS="quote">You're effectively changing the final drive ratio by doing that, not the individual gear ratios.</TD></TR></TABLE>
Yep, and likely get worse gas milage.
Your car was designed to get peak gas mileage at it's factory tire size.
Old May 17, 2007 | 11:54 AM
Many said if I go with a shorter profile tire, I was suppose to be quicker off the line. Why can't the same thing be said for taller tires?
Old May 17, 2007 | 11:55 AM
PhatBoy5015's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YipMan_Style &raquo;</TD></TR><TR><TD CLASS="quote">Many said if I go with a shorter profile tire, I was suppose to be quicker off the line. Why can't the same thing be said for taller tires?</TD></TR></TABLE>
They weigh more
Old May 17, 2007 | 12:18 PM
Team RS2's Avatar
Default Re: Changing my gear ratio by changing my tires (PhatBoy5015)
when you change wheels and tires you mess with fuel milage, speed, gear ratio, weight, and traction
Old May 17, 2007 | 01:54 PM
gotbooost's Avatar
technically if you raised the tire size by enough you would be effectively lowering your rpms at all speeds
so if you're doing a lot of freeway driving then you could be increasing mpg because of the lower rpms at freeway speeds/long distance driving.
i don't know how much you need to change to notice a difference though.
Old May 17, 2007 | 02:01 PM
Ek Forever y0!
Default Re: (gotbooost)
Well, too much bigger and it will be harder on his valvetrain, driveline, and transmission, thus creating more work for your engine.
Closest to stock size will net you good gas mileage.
Old May 17, 2007 | 02:04 PM
Team RS2's Avatar
Default Re: (ek forever guy)
valvetrain driveline and transmisson
#1 how can it be bad for his vavle train do know what a valvetrain is?
#2 driveline is slang for engine and tranmisson
#3 see #2 <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Well, too much bigger and it will be harder on his valvetrain, driveline, and transmission, thus creating more work for your engine.
Closest to stock size will net you good gas mileage.</TD></TR></TABLE>
Old May 17, 2007 | 03:31 PM
Bakeoff's Avatar
wow, you guys all suck, giving him such shitty, one sided info.
Changing between those two sizes of tires, you shouldn't notice any difference in mileage. If nothing else, the larger tire will travel more distance over time the odometer clocks a mile. Getting slightly less in miles per gallon, while clocking less distance than you have gone, it balances out. There's no point in doing it, unless your tires are bad.
****** kids.
Old May 17, 2007 | 05:50 PM
93baggedcivic's Avatar
Default Re: (Bakeoff)
look i work in a tire shop if you put them tires next to each other your not even going to see a difference its such a small difference its not going to do anything.we change sizes all the time.its not a big deal
Old May 18, 2007 | 07:18 PM
Flash202's Avatar
Default Re: (93baggedcivic)
if you know you gear ratios I have a excel program that is a speed calculator that includes tires size and rpm that will graph and tell you your top speed let me know if your interested
Here is is http://www.k20a.org/upload/GearRatioCalculator.XLT
You must use the overall diameter of rim and tire in inches,,,,
Old May 18, 2007 | 09:04 PM
96GSRcx's Avatar
Default Re: (Flash202)
Fatboy Transmission Gear Ratio Calculator
Same basic thing, just easier to use.
chicken head
Apr 13, 2006 02:28 PM
Integ03
Aug 13, 2005 10:41 PM
Honda318dx
51
May 27, 2005 09:59 AM
swrdply400mrelay
Dec 18, 2002 04:06 PM
b18cTurbo
Feb 26, 2002 02:17 PM
