Your thoughts on my set-up?
Old May 16, 2007 | 07:37 PM
enduronut's Avatar
Default Your thoughts on my set-up?
Here is my plan, any thoughts or other ideas would be appreciated, I have a b20 block 84.5mm I am looking at CP 12.5:1 pistons with everything else in the bottom end to remain stock, complete rebuild but thats it. For the head I would like to run my fully ported and polished LS head, crower dual valve springs, and crower 403's. I am wondering if this set-up will have a clearance issue (pistons hitting valves)? The reason I am doing this is to get some cheap power that will last about 250 miles of pure pounding. I race this car and the races are only about 10 mins long 15 laps on a 1/3 mile track and I will rebuild after every season. VTEC is illegal in this class or I would be doing LS/VTEC. Any other ideas would be appreciated too. Thanks Chad
Old May 16, 2007 | 07:48 PM
b19coupe's Avatar
Default Re: Your thoughts on my set-up? (enduronut)
You will not have piston to valve issues.
Ever thought of trying to modify a GSR intake manifold to fit?
It gives you a nice broad torque curve
This motor is 85mmx89mm with 11.5:1 compression and is running cams equivalent to 403's. For your application you might want to step up to the 404's.
Old May 16, 2007 | 07:52 PM
MR.johnson's Avatar
Default Re: Your thoughts on my set-up? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">You will not have piston to valve issues.
This motor is 85mmx89mm with 11.5:1 compression and is running cams equivalent to 403's. For your application you might want to step up to the 404's.</TD></TR></TABLE>
post a pic of the flange that bolts to the head.
Old May 16, 2007 | 08:01 PM
fast4imports's Avatar
are u planning to pin fit the rods and run stock rods??...becuase i wouldnt reccomend it...it would really help u out if u got new rods ...with forged pistons and some nice rods there is no reason u would have to pull apart the motor every season should last longer then that...all depends on what ur spinning it too...
Old May 16, 2007 | 08:02 PM
UncleD's Avatar
Default Re: Your thoughts on my set-up? (fast4imports)
Wow Todd thats ****** awesome!
Old May 16, 2007 | 08:08 PM
b19coupe's Avatar
Default Re: Your thoughts on my set-up? (MR.johnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR.johnson &raquo;</TD></TR><TR><TD CLASS="quote">post a pic of the flange that bolts to the head. </TD></TR></TABLE>
Old May 17, 2007 | 09:54 AM
MR.johnson's Avatar
thanks.
Old May 17, 2007 | 11:18 AM
4g hatch's Avatar
b19 coupe is that manifold hard to make work. im not the best at custom fabrication but that looks interesting until i can save for a vtec head. how did you make it work with the secondary butterfies
Old May 17, 2007 | 03:02 PM
b19coupe's Avatar
Default Re: (4g hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g hatch &raquo;</TD></TR><TR><TD CLASS="quote"> how did you make it work with the secondary butterfies?</TD></TR></TABLE>
I used the VTEC output to trigger a relay that shuts off current to the IAB control valve. An added bonus was high and low speed ignition/fuel tables to play with in Hondata
Old May 17, 2007 | 05:13 PM
flyrod's Avatar
That's cool; thanks for posting the pictures. btw, how many HP is the adobe block good for?
JDM Projects
Oct 6, 2010 07:00 PM
Si_Guy2000
Jan 13, 2007 03:44 PM
DC4cedInducted
Dec 13, 2005 03:23 PM
DOHC VTEC EG
Jul 5, 2004 11:17 AM
Bigjussin
Oct 24, 2002 05:45 PM
