B20/Vtec Questions
Old Oct 24, 2002 | 10:57 AM
Bigjussin's Avatar
Default B20/Vtec Questions
Will I have to mill anything on my P72 Gsr head to fit the JDM B20b block? Any idea about the valve relief clearance?
thanks mucho
Old Oct 24, 2002 | 11:03 AM
sgT's Avatar
sgT
Default Re: B20/Vtec Questions (bigjussin)
other than the usual dowel pin moving and oil port plug, the head is fine.
You might want to open up the valve reliefs on the stock pistons though.
Old Oct 24, 2002 | 11:26 AM
JCushing's Avatar
Default Re: B20/Vtec Questions (sgT)
you might want to? or you have to... i was planning this same thing and was wondering what the for sure answer was
Old Oct 24, 2002 | 02:38 PM
Bigjussin's Avatar
Cut the pistons? I am assuming a 3-layer head gasket would be a wise decision in this case too?
thanks again, i appreciate the help
Old Oct 24, 2002 | 03:03 PM
JCushing's Avatar
yeah stock head gasket no milling of the head unless nessicary....
the thing is with b20 pistons honda designed them to work with 31mm intake valves.. your putting 33 mm vtec valves in there and there just too wide... there is a chance of the valve hitting the edge of the valve relief of the piston.. im in the process of figureing out just how likely piston to valve contact is with no advance and no milling..
Old Oct 24, 2002 | 05:45 PM
Bigjussin's Avatar
Default Re: B20/Vtec Questions (JCushing)
Hey, add me to your AOL IM list, since we are both considering the swap, i'd be happy to share info on stuff i find!
Han Solo
13
Feb 1, 2006 02:53 PM
RTW DC2R
Jul 2, 2004 09:33 AM
RTW DC2R
Jun 24, 2004 12:55 PM
Ri5e
Mar 20, 2002 12:08 PM
