Manual Tension Conversion...SEARCHED
Guest
Posts: n/a
Found 3 diff sets up part #'s. Also if i already removed my balance shafts do i need....
BRACKET, BALANCER BELT ADJUSTER and ADJUSTER COMP., BALANCER BELT
here are the 3 diff sets of #'s i found
13404-PT0-004 - ADJUSTER COMP., BALANCER BELT
13415-PT0-000 - BRACKET, BALANCER BELT ADJUSTER
14510-PT0-004 - ADJUSTER COMP., TIMING BELT
14516-PT2-000 - SPRING COMP., TIMING BELT ADJUSTER
14521-P14-A00 - PLATE, ADJUSTER
90014-P14-A00 - BOLT, TIMING BELT ADJUSTER BASE
90015-PT0-000 - BOLT, TIMING BELT ADJUSTER SPRING
90016-PT0-000 - BOLT, TIMING BELT ADJUSTER
90140-P14-A00 - WASHER, PLAIN (11MM)
13404-PT0-004 - balancer belt adjuster
14510-PT0-004 - timing belt adjuster
14516-PT2-000 - adjuster spring
90014-P14-A00 - adjuster base bolt
90015-PT0-000 - adjuster spring bolt
90016-PT0-000 - adjuster bolt
90140-P14-A00 - 11mm washer
14521-P14-A00 - adjuster plate
90501-MB7-610 - washer
90216-P0A-000 - nut
90401-PT0-000 - rubber o-ring
14510-pt0-004 this is the Adjuster, Id suggest a Timken from AutoZone. Its only like 36$ @ honda its 68$. Auto zone can cross refrence the part #'s. The manual tensioner is on the 2.3l.
14516-pt2-000 spring 4.08$
90014-p14-A00 Bolt 3.85$
90015-pt0-000 Bolt 7.15$
900616-pt0-000 Bolt 8.48$
90140-p14-A00 Washer 3.22$
90216-P0A-000 - nut
If you remove the balance shafts, just get some washers to hold the timing belt tensioner pulley down.
All you need is the timing belt tensioner pulley, the bolt it mounts on, the triangle plate, the spring perch, and the tensioner pivot bolt, and then some washers.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">If you remove the balance shafts, just get some washers to hold the timing belt tensioner pulley down.
All you need is the timing belt tensioner pulley, the bolt it mounts on, the triangle plate, the spring perch, and the tensioner pivot bolt, and then some washers.</TD></TR></TABLE>
what parts do the washers replace? are the washers from honda?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maharajamd »</TD></TR><TR><TD CLASS="quote">Just buy the conversion kit from irp...it is like 90 bucks and comes with everything needed.
I just did mine. Pretty easy really.</TD></TR></TABLE>
irp? are they on here? anyone else use this kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism »</TD></TR><TR><TD CLASS="quote">get the damn balance shaft pully from the h23 and use that. dont use stupid wasers from a hardware store.</TD></TR></TABLE>
waste of money.
that thing is like $50
waste of money.
ShortyzKustomz
Jan 12, 2008 09:56 AM
Haleiwa-Brando
Mar 31, 2006 07:10 PM
14521p14a00, 90140p14a00, 90216p0a000, adjuster, autozone, conversion, engines, h22a, honda, irp, kit, manual, plate, prelude, pto, series, tensioner
