Which rear T mount do i use?
i have a jdm b16a going into an eg. i got the 94-01 integra rear T mount but it doesnt seem to fit. so i guess since my engine goes along with the older 90-93 integra b18a T mount?
or is it possible to use the 94+ one?
thanks in advance.
Modified by egb16pg at 5:58 PM 5/16/2007
thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abusedhusband »</TD></TR><TR><TD CLASS="quote">if you have the 94-01 t mount you have the right one</TD></TR></TABLE>
is anyone sure on this?? remember that this is the older cable b16 similar to the old cable b18a so wouldnt i have to use the rear T off the older integras also?
thanks for the help abusedhusband.
1 mistake people commonly make on these swaps
YES-94-01 Integra T-Bracket
YES-it MUST be from a manual if you are using a manual transmission
if you are experiencing problems lining up one bolt hole after you get on bolt in on the backside of the tranny, then you've got yourself an automatic tranny t-bracket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1jdmferio »</TD></TR><TR><TD CLASS="quote">1 mistake people commonly make on these swaps
if you are experiencing problems lining up one bolt hole after you get on bolt in on the backside of the tranny, then you've got yourself an automatic tranny t-bracket</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb16pg »</TD></TR><TR><TD CLASS="quote">
also you absolutely cannot use the 90-93 integra t-bracket as the bolt that attaches to the rear motor mount is about an inch and a half to two inches kicked to the left when the top tranny mount is put in place.
</TD></TR></TABLE>also you absolutely cannot use the 90-93 integra t-bracket as the bolt that attaches to the rear motor mount is about an inch and a half to two inches kicked to the left when the top tranny mount is put in place.
also you absolutely cannot use the 90-93 integra t-bracket as the bolt that attaches to the rear motor mount is about an inch and a half to two inches kicked to the left when the top tranny mount is put in place.</TD></TR></TABLE>
x10000000000000000000000
made that mistake once
dem0nk1d
Nov 21, 2008 09:44 AM
